Question about Bose 161 Rear Speaker
I have the bose 161 rear speakers and I have no sound coming out of the left speaker the wires are right if its the speaker what part in the inside could it be ?
freetek
  • 5568 Answers
SOURCE: how do i open the speaker to reconecct the wires inside?
It may not be only wires loose; the speaker(or speakers) may be damaged.
The common 'dynamic' speaker has a centered magnet in an assembly that extends the field of the magnet around a coil of wire on a form called the 'voice coil' that is firmly attached to the cone which moves in and out to 'pump' air and produce sound.
The clearances (gap) between the magnet assembly and the voice coil that sits in a narrow space between the magnet and the outer field piece is very small and critical.
Once positioned in the factory, glue is used to keep the field assembly from slipping and rubbing against the voice coil.
A strong shock will break the glue bond and, if severe enough, clamp the voice coil so it cannot move freely any more.
Since the Bose is a quality product, the cabinet may be assembled with glue and screws that are concealed.
If you know someone with a simple multimeter, they may be able to check at the terminals to see if there is any continuity from the terminals to the speaker.
If it doesn't have any, then perhaps only a wire is broken between the terminals and the speakers.
There is with high probability also a filter inside that separates the frequency range and sends the signal to separate speakers that produce different ranges of sound.
Posted on Jun 26, 2008
  • 4234 Answers
SOURCE: Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Posted on Oct 08, 2008
  • 51 Answers
SOURCE: Bose Cinemate speakers stopped working
Sounds like you need to take them back for exchange. A new electronic product is most likely to fail in the first few months, when any weak or defective parts that made it through final test at the factory decide to **** out after a few hours of use. This is a very common situation, especially nowadays with manufacturers buying the cheapest parts they can find, and the general public crying out for lower prices instead of paying more money for better quality. Bose has traditionally been "top of the line" stuff, but even they have to cut corners to keep prices low and sell stuff in this economy.
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: I lost sound on one
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Posted on Jan 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Posted on Feb 03, 2010
How to remove rear speakers fome 1999 infiniti i30
from inside? first remove what can be removed and see if you can reach for some more.
Sep 06, 2014 | Bose 161 Rear Speaker
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 01, 2014 | 2005 Hummer H2
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
How to open a BOSE 161?
Yes, the grill can be removed. To pull out the grill you need to clamp on the sides but inside between the outside of the mesh and the outside part of the main plastic housing. pry at least a one incu on both sides, clamp it and wiggle it up until it pulls out. to reomve the speak is more work, on the center of each side, you will want to use a 1/4" screwdriver, but nice and thick. slide it on the center of one fo the sides of the speaker downward. looking downward on it, you will see two dimples with the center opened. slide the screwdriver between the dimples at least 1/4" down and thenbend outward slightlight the scredriver so it can grab on to the opening underneath the dimples., keep doing this on all four sides until it is loose enough for you to wiggle it our by hand. do note, that the wires inside are real short, to remove the speakers completely you will need to unwind the wiring attached. the wire is solid not mesh, so you will need to use a tweezer of sort or micro screwdriver(such as for glasses) to loosen the wires. once that is done, you can pull out the speakers a swell as other components. remember, the wires inside are real short. not long enough to disconnect them, a little work is needed to disconnect the wires.
Jun 15, 2012 | Bose 161 Rear Speaker
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
I just removed the factory Bose speakers from my 1995 Nissan Maxima. Each speaker has its own amplifier. I need to know what each wire, (inside each speaker housing) is for? There are 4 wires going to...
two are for your speakers the other two for your amp.
Left front: (+) yellow (-) brown
right front: (+) violet (-) light green
left rear: (+) red (-) green
right rear: (+) pink (-) blue
this should help.............
Apr 16, 2011 | Car Audio & Video
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Bose 161 Rear Speaker Logo
60 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
