Question about Apple iPod MP3 Player
How can i add new music to my ipod a1059 - Apple iPod MP3 Player
5 Suggested Answers
tigerlady
  • 14 Answers
SOURCE: changing music on ipod
connect it up to the pc,wait till its recognised,go to my computer,open it and look for a drive g,right click on it and then format,this will get rid of the music and anything else you have on there and you can then add new,or the alturnative is to go to driver g,explore it and delete music files manually.if not clued up on it the easiest way is to format.ok
Posted on Jan 26, 2008
  • 163 Answers
SOURCE: IPOD how to move music
hi,
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Posted on Dec 15, 2008
meeknotweak
  • 341 Answers
SOURCE: I presently have a Ipod Nano 8gb music library set
Aaah, very simple procedure. First, plug your new iPod into your computer. Second, open up iTunes. Third, your computer should recognize your new iPod and will prompt you to go through a simple iPod set up, then it will ask you if you want to sync your music library to it.
Hope this helps!
Posted on Apr 04, 2010
SOURCE: The circular control of my ipod Model A1059 is unr...
ipod model a1059 20gb not cannect with pc
only charging warking but not on
Posted on Jul 08, 2010
Can a model A1059 ipod be charged via usb?
yes, but you need to have itunes on the computer you are charging it from.
Feb 18, 2013 | Apple Ipod Gen 4 A1059 U2 4th Gen 20GB and...
Tip
How to Sync an iPod without Deleting the Old Music on Mac?
Question:I got a new computer and just installed iTunes 9.0 on it. This iTunes 9.0 is a complete new one. Now I really want to transfer this iTunes 9.0 library to my iPod. How could I do this, Anybody help?
Answer: Once you sync your iPod to this iTunes 9.0, of course the iTunes 9.0 playlist will sync your iPod, but all the old music on your iPod will be deleted after the syncing. If you want to sync the iPod without deleting the old music, you should get some transfer tool.
iMacsoft iPod to Mac Transfer - Professional tool to sync an iPod without deleting old music on Mac! You can sync any music on your computer and add any playlist on iTunes to an iPod without losing the old ones with it. Guide: Sync an iPod without Deleting the Old Music on Mac Step 1. First, free download, install and run it
Step 2. Open the library/playlist that you want to transfer and click the "Add Files to iPod" or "Add Folder to iPod" button to sync an iPod without deleting the old music.
ipodtomac-sync-2.jpg Step 3. Edit iPod Playlist
To those who want to create their own personalized iPod Playlist, you can try this function.
Choose the "File -> Playlist" option to create a new list , and then choose the "New Playlist" option from the submenu. Drag & drop to import or export files need and drag it to the local, or you can choose the file from the local and drag it to the iPod.
Congratulations! You have done that!
I like ipod/iphone/PSP, I also like to transfer files with ipod freely. And if you you are also looking for how to do it, follow this site:
http://www.ipodtomac.biz/
http://www.ipod-to-pc.net/
http://www.youtubetoipod.org/
Have a good day!
on Jun 18, 2010 | Computers & Internet
Ipod model A1059 how to work controls
this is a quickguide to start using your ipod http://support.apple.com/kb/HT1345
details on how to use a 4th generation ipod here http://www.apple.com/support/ipodnano/
Aug 10, 2010 | Apple iPod 4th Generation MP3 Player
I have two ipod video's a1099 and a1059, They were dead wont turn on wont charg,, I got two new battery's The a1099 came on with new battery and had about 1/2 a charge, charged it last night just...
Hi, answer a little bitlong, you can use this links to reset the ipod.
reset-ipod.com/reset-ipod-video.htm
or
support.apple.com/kb/ht1339
or
wikihow.com/Reset-an-iPod
or
support.apple.com/kb/ht1320.
Hope it helped. await your comment.
Take care.
Jun 06, 2010 | Audio Players & Recorders
The circular control of my ipod Model A1059 is unresponsive. What can be done?
May 19, 2010 | Audio Players & Recorders
Ipod formatted for mac....i have windows.......i need to recover
If you want to hook it up to windows,..
go to http://www.apple.com/itunes/download/
And download itunes for windows. then install it.
Then restart your computer and hook the ipod to the computer..
it should now be recognized and start itunes, which will allow you to transfer music on and off the ipod
Apr 08, 2010 | Apple iPod MP3 Player
How do I simply add the new music?
An iPod can be synced with only one iTunes library at a time. once you got a new iTunes library or a new computer. You have to authorize your iPod to it at first, then you can upload music and video from the new iTunes to your iPod. But this way will overwrite the originial files on iPod with the new iTunes. You may try this iPod transfer, it can help you copy files from iPod to computer for backup, you can also use it as an iTunes alternative to upload music and video. It will not erase your original iPod files. It's safe and works pretty well for me. http://www.ipod-transfer-copy.com/ipod-transfer-mediawidget.html
Hope it helps. Contact me if you have any other question.
Jan 31, 2010 | Apple iPod nano
Tried to do a restore on my 40 gig Ipod A1059. It started the restore and then it went to a screen showing a wall adapter. I always charge via USB and don't have a wall adapter. Help!?!
Sep 22, 2009 | Apple iPod MP3 Player
I cant get the music from my pc to ipod.
If you have itunes loaded on your pc and your are updating the music from itunes to your ipod it should be okay, unless you have moved the folder which contains your music. If you have you will need to open itunes go to file>add folder to library and add your music folder, It will update your library with your music files. Then plug your ipod in and it should automatically update your ipod if you have already created a playlist for it. hope it helps. theres is a new version of itunes out now. If you haven't got it already then download it (its free) and take it from there. You need to add the music to itunes, just go to add folder (or file) to library and choose the path where your music is. Good luck
Oct 26, 2008 | Apple iPod nano
Apple iPod MP3 Player Logo
126 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
