Question about Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive
Cannnot open Beyond Micro Mobil, Moidel BMMDU2
When first purchased I stored data on the external hard drive, but cannot open the drive to either restore or delete data it contains. I had XP before and currently have vista.
Just purchased a new Acer laptop and I've been trying to get my Beyond Micro Model# BMMDU2 external hard drive to work?
Try Aomei partition assistant (free)
https://www.aomeitech.com/aomei-partition-assistant.html
Dec 31, 2017 | Acer Computers & Internet
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My Beyond Macro External hard drive model no BMMDU2 has stopped working.. It shows up in list of "Safely remove Hardware" but windows XP professional SP3 is not assigning any letter to...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro BMMDU2 250 GB external hard drive not working
It is highly unlikely that it will work. A circuit board from the same make and model hard drive would be a better choice, but I think a fire damaged hard drive would not work with a functioning circuit board. It depends upon how much heat the hard drive was subject to.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their services. Depending upon how valuable your data is, I suggest you get a quote first.
Apr 01, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
External Hard Drive - Beyond Micro
I have the same BMMDU2. It's used 12V/1.5A power suply.
May 11, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Beyond micro mobile disk BMMDU2 is not recognized
The drive USB interface may be damaged; an external case is available form various vendors for about $20. The drive should pop out and into the new case. If still not recognized, then the ID track on the drive may be compromized - that can happen if the USB is unplugged while it is still writing to the drive. There is drive recovery software out there, like EASEUS that works quite well (they have a demo that you can try free) to see if that would work.
Apr 18, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I plag my BMMDU2 in 2 my computer & it does not show up anywhere
The only solution that I have found, due to having same problem, is that original power supply is too low at 1.5 watts. 3 things to try.
1 - purchase another similar external hard drive and use its power supply. (I bought a Maxtor Driive with same plug at 2.0 watts)
2 - purchase power supply from radio shack with higher watts. take drive in with you for tech to match it up.
3 - Remove the Hard Drive from tthe case and connect to a PC as a slave Hard drive.
Any option may or may not work, but worth the try when invaluable data is on your drive.
Jan 27, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive Logo
76 people viewed this question
Top Beyond Micro Computers & Internet Experts
Dean Rigsby
Dean Rigsby
Level 1 Expert
Joe Bit
Joe Bit
Level 1 Expert
Harry
Harry
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
