FRA125CT1 cycles on and of after 45 seconds - Heating & Cooling
  • 53 Answers
Over heating please clean coils before you damage the compressor thermo protector is kickin in thats why it comin on an off thanks
Posted on May 16, 2010
Dryer starts about 45 seconds into the cycle lights come on and then it starts beeping like the end of the cycle. 10 seconds later off. Very warm on top of the machine.
See my tip for buzzing dryer. Check Owner's manual, Troubleshooting. Sounds like air is not moveing and High temp cut off saftey switch doesn't like the lack of air flow. Duct clean? Check air flow from the outdoor vent. Clean vent tube/s
Mar 04, 2015 | Kenmore Dryers
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Compressor runs 45 seconds off for 2 minutes cycles like this no voltage change
In order to accurately determine and diagnose the problem, a more detailed description of the problem needs to be communicated as opposed to normal operation of the system so a repair person can determine that there is in fact a problem. There's a big difference between solving a problem via text as opposed to seeing what is wrong in the field. They rarely are the same.
Goodman condenser sequence of operation on a matched system. Call for cool, condenser starts, 15-30 seconds later blower motor starts, cool satisfied, condenser shuts down, 15-45 seconds later blower motor shuts down. House heats ups and a call for cool via the thermostat starts another cycle.
Based on normal operation it is impossible to determine whats wrong with the information given. There are perhaps 5 voltage measurements in the system that you could be referring to.
Aug 19, 2009 | Goodman Heating & Cooling
Kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
May 03, 2009 | True Refrigerators
NEtgear RP614 cannot connect after a electricity shortage in our home :(
How is it not working? You get limited or no connectivity or it isn't functioning at all. Firstly, let's do a power cycle. Push the reset button for 5 seconds, unplug for 45 seconds, and reset 5 seconds, and unplug for 45 seconds. If that doesn't work try a hard reset. Alright, it's time to do a hard reset, this will rest all your passwords, Take a Pen or a pin, push the pin the the reset hole for 45 seconds, Uplug the modem for 1 minute, reset hole for 30 seconds, unplug for 30 seconds, and it should be hard resetted also power cycle.
Aug 25, 2007 | NetGear RP614 Router
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
