Question about Car Audio & Video
PIONEER KEH-P4600R error code 70
My disc is stuck in the unit unabling me to eject the cd changer how do i get it out
  • Sandford Sep 02, 2008
    I have the very same problem if anyone has the solution?
tech48
  • 624 Answers
SOURCE: bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Posted on Jul 01, 2008
  • 651 Answers
SOURCE: CD Changer is stuck
drop the faceplate, there should be a tiny hole you can push a paper clip in. push in a little bit and it should eject. good luck
Posted on Dec 01, 2008
SOURCE: 6 disc CD changer is stuck
This happened to me a few years ago. It wouldn't eject the CD for a year. I literally smacked the side of the dash where the cd player is located and it came out the next time I pressed eject. I found that same solution in a couple of forums. I had to do it a few times. I think the CD just has to allign with something to eject properly.
Posted on May 12, 2009
greg_margo
  • 1959 Answers
SOURCE: 6 disc changer will not eject cds==
One common solution is to disconnect the negative battery cable for 10minutes. When you reconnect, the stereo should reset itself and allow you to eject your CD's . Best of luck!
Greg
Posted on May 20, 2009
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
I have a pioneer keh-p5400
You are not going to be able to find a new radio that will run a changer.
Nov 10, 2011 | Pioneer KEH-P5400 CD Changer
Error 60 each time i try to change disk in pioneer keh p3600r
manual should have a list of error codes ,pioneers pretty ok like that , u can call them direct , meantime make sure disc is clean ,try store bought disc , not burned ones , sounds like a mechanical faliure , if unit was recently shipped to you , it may have required "transport "screws . disc tray may have slid into playing area inside unit .
Nov 14, 2009 | Pioneer CDX-P1230S CD Changer
I have a CDX-FM65 Pioneer 6 disc player. The
I have a pioneer universal multi-cd system cdx fm65, the remote indicator unit display will not come on when you masn the handheld remote what do I need to do?
Jun 28, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Not working error 50 and 70
Clean the unit if possible. does the cartridge eject? if so, load it with a cd player cleaner, preferrably one that uses a cleaning solution. put it in tray slot 1. load and wait. try this a few times then try a good disc, one that is not scratched up. changers are hard on cd's. If it's still not working, below the cartridge slot there should be an inverted dimple that you can press with a ball point pen. This is a reset. It should have this button, I just can't remember the exact location if it's not right there. Hope this helps. If you have a spare cartridge try that as well, as they warp.
May 24, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
Lost cable between changer and head unit for CDX-P25
http://www.hermanelectronics.com/HermanStore/homepage.asp
www.vancebaldwin.com
www.partstore.com
Jan 12, 2009 | Pioneer CDX-FM1277 12-Disc CD Changer
Error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Dec 05, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Pioneer 10 disc changer magazine stuck
i would like to be of assistance but i need to know the which pioneer 10 disc changer it is. send me the information and i may be able to help. thanks
Nov 26, 2007 | Pioneer 6CD CHANGER
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Car Audio & Video Logo
468 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
