Question about Kenmore 73952 Gas Dryer
Dryer will not heat
I had this problem, changed the coils igniter and it still did not work. changed the thermal fuse and problem solved so i thought. put a load of clothes on and they did not dry, assumed the thermal fuse blew again so i bought another thermal fuse and the thermalstate that is right next to it.... the ones i removed were still good. i am at a lost on what the problem is now
  • chicken835 May 17, 2010
    When i did the initial changing of the coils i cleaned all the visible lint that i could vacume up
    i will see if i missed and thing tonight... but it worked and then does not work now... something electrical that does not allow electricicty to get to the igitor of the gas coils is going on. You do not hear that click that happens right before the gas ignites.
  • chicken835 May 19, 2010
    Well cleaned all air passages and it still does not work.
  • 10,319 Answers
Probably nothing is wrong with the unit mechanicaly & electrically wise. Remove all vent tubing and thoroughly clean all lint out of the exhaust tubes. You will have a load of lint I will expect accumulated inside of yours. Once it is all removed the dryer will heat up back to the normal settings it had before. The moister control sensor will prevent the burner to ignite if the exhaust is plugged up with any obstruction especially lint which is a fire hazard
Posted on May 16, 2010
  • frank thomas wilson
    frank thomas wilson May 18, 2010
    If you do not hear the click of the spark ignitor replace that part for it is the fault you have with this dryer
Dryer stopped heating how do you light the pilot
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.
Mar 14, 2011 | Crosley Dryers
No heat
Hello there:
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Sep 26, 2010 | Roper RGK2951W Gas Commercial Dryer
Gas will not ignite
No heat If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Dec 31, 2009 | Kenmore 74112 Gas Dryer
My Neptune dryer mdg5500awgg wont heat up. Any suggestions?
I am providing some links courtesy of www.repairclinic.com that will assist you in the diagnose/repair of your dryer.
Firstly, ascertain that you have made a positive heat selection on the control panel switch, then proceed onward.
Parts breakdown/disassembly procedures:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Igniter
Gas valve coils
Thermal fuse
1. Gas Valve Coils image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3479&PartID=3479
2. Ignitor image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3018&PartID=3018
3. Thermal Fuse image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di516650&PartID=516650
Aug 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The dryer runs, but there is no heat. Gas is
Igniter
Gas valve coils
Thermal fuse
Aug 20, 2009 | Kenmore 700 6972 Dryer
I have a gas dryer , dryer only runs on air. There is no heat. What is causing the problem? Please advise!
Igniter
Gas valve coils
Thermal fuse
Aug 03, 2009 | Dryers
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Dryer working but no heat
If it does not heat , and you already checked the burner and the ignitor, then it is probably the thermal fuse at the back of the appliance.
See the following suggestions from Repairclinic:
Igniter
Gas valve coils
Thermal fuse
Oct 09, 2008 | Dryers
Gas Dryer will not heat
I replaced the thermal fuse and it fixed the problem. I had to remove the blower housing cover on the front of the machine to get to the thermal fuse. There was was an incredable amount of lint in there that I cleaned out. I used one of those lint brushes on a regular basis to make sure the machine is clean. That brush doesn't do a very good job. My wife said that the clothes dry about 10-12 minutes faster.
Dec 22, 2007 | Dryers
Kenmore 73952 Gas Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
