My speakers are not making any sound, though the volume throughout the system is at full and the device is enabled.
  • 813 Answers
Ok
see the pin ur plug in rigt o/p pin if u not plugin propre then plug in o/p port
then after chak the driver & driver is bed then reinstall ur sound drivers
Posted on Mar 31, 2008
SOURCE:
3130 no sound but power is on and volume control is full
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 20, 2012 | Creative Technology Creative Inspire T3130...
No audio working
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Sep 22, 2011 | Insignia 2.1 Speaker System (3-Piece)
No sound even though speakers are already plugged in.
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 30, 2011 | Computers & Internet
My sound card is not working though the drivers are installed...reply back [email protected]
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 16, 2011 | Intel D915GLVG Motherboard
The speakers dont work even though the whole system is plugged correctley the light that should be lite near the volume controller is not working kindly help me in knowing the problem
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you dont have a motherboard disk you will need to download the sound drivers
also
if you need more help with this posta reply
hope this helps
Aug 15, 2011 | Creative Labs Inspire T2900 Computer...
Very low volume output at full volume
Jul 03, 2011 | Polk Audio AMR2 Computer Speakers
Hi i have the Bose companion 5 speakers today there was a power cut in my flat. after that my speakers are not working anymore. the thing is that the led on volume control is on (green) and my pc...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Mar 30, 2011 | Bose Companion 5 Multimedia Speaker System...
My logitech computer speakers have been broken for about two years now, and i have Windows XP. If i click on 'Control Panel' and then 'Volume Control' its not letting me drag the volume to full, even...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 23, 2011 | Logitech X-530 Computer Speakers
I am not able get sounds & audios from my laptop even though I have all the relevant sounds drivers to sounds. [email protected]
also
hope this helps
don
Feb 18, 2011 | IBM ThinkPad Soundcard
My laptop compag610 ,os is xp, now the sound not enable
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Jan 28, 2011 | Compaq Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
