Question about Maytag Neptune MCE8000AY Electric Dryer
Doesn't tumble but does get hot. - Maytag Neptune MCE8000AY Electric Dryer
  • 10,319 Answers
Check your exhaust vents system first. If plugged up the sensor will prevent the heating grid to operate
Posted on May 16, 2010
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Tumble dryer not getting hot
Likely to be a thermostat or heater element problem.
These are located at the rear of the dryer, behind a removeable cover, but you will need a test meter to check them out.
Hope this helps.
Dec 15, 2009 | Hotpoint Dryers
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Non-tumble
were talkin dryer here right?? not wssher.. the no tumble feature , is you using the shelf, the unit will still tumble so as not to overheat amd move the hot air around, however since your item is on the shelf its " no tumble". no problem with unit
Mar 29, 2008 | Kenmore Elite 45986 Front Load Washer
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer
If you here motor running, you have a broken belt. Give brand and model and I can help you change it.
Nov 21, 2007 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
81 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
