Question about Sony 11-18mm f/4.5-f/5.6 Super Wide-Angle Zoom Lens for Select SLR Cameras
Dropped camera and landed on lens the auto focus motor seems to be jambed and does not move can I get it repaired? the uv filter broke the lens itself is good.it does get the green focus box and work at certian distances..
    Scholar:
  • 117 Answers
Look for a local camera repairman, but Sony may be your best bet- Glad you don't want advice on repairing yourself- that would be a nightmare
Posted on Jun 02, 2010
I dropped my camera and hit the lens and now auto focus does not work
You'll probably need a professional repair. Compare the cost of repair with the cost of replacement. On that lens it could be about the same.
Dec 17, 2012 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
My autofocus will not work all the time. when I want to zoom in for closeups it will be out of focus
This means that there is a alignment issue as the auto focus seems out of setting. This can be due to damage on the settings or a possible shift in the lens setting. This is due to a damage on the lens setting or a jammed motor drive. You will need some expertise to remove and check or reset the lens settings. If not take consensus as a false move can do more harm. need to remove the camera and the auto focus in the lens hood to test the motor drive, movement and action.
Oct 09, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
My 18-55mm lens won't auto focus...it works in manual my 55-200mm works fine on my D3000
-You must use a lens with internal auto-focus motor such as AF-S Nikkor, or 3rd party with built-in motor
-Is the switch`s been moved to A/M??
-The battery must have enough power to run the auto-focus motor inside the lens
Dec 25, 2010 | Nikon D3000 Digital Camera
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
Sep 24, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto-focus does not work
lower focus mirror post needs to be fixed
Mar 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Canon Rebel Xti Wont autofocus
I dropped my camera and thought the autofocus broke. It turn out that it swithed from autofocus to manual focus. There's a switch on the lens. Check if that's your problem too.
Sep 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D200 Auto Focus
It seems to be a problem with the internal working of the camera its self. I have requested a replacement fro my seller. Thank You Samuel
Apr 06, 2008 | Nikon Cameras
Problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
Dec 09, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Sony 11-18mm f/4.5-f/5.6 Super Wide-Angle Zoom Lens for Select  SLR Cameras Logo
108 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
