Hello i have a tascam 244 which is a four track tape recorder it is quite old i have sent it to tascam to have it fixed before but now it is not working,the metre lights come on for each track and the tape plays but there is no sound coming out of it.
  • vagra
    vagra Apr 02, 2008
    dear dan thank you for your reply,i have jusy checked again the tascam the lights come on on the metres but there dials are not moving when i play a tape.It will cost me £35 pounds just for some one to look at it and another £10 to £20 to send it.It really is not worth it i've had this fixed before,the only reason i wish to use it is so i can put all the old tunes onto my copmputer.the tape player runs,bu the needles do not move.
    thanks again mate colin
  • vagra
    vagra Apr 02, 2008
    thank you dan will have a go,but there is no sound coming out
    all the best.
  • 4,234 Answers
Since there is movement in the meters, the heads are good. Look first for any cables or connectors that are loose. There is an "output" section in these that can fail. I don't recall whether this section is an IC or discrete components though. Check the cables and connectors and update this with what you find. I'll look up this model and find the output parts.
Dan
Posted on Mar 31, 2008
  • ABRsvcs Apr 02, 2008
    If the meters are not moving, I would first clean the heads with alcohol. Next, with the unit unplugged, look for the switch that is engaged when the unit is in record. This is usually a fairly long switch with multiple pins. If you see this one, spray it with an electronic switch cleaner (one that contains a lubricant too) and work the switch by hand back and forth (or up and down). If there is some dust/debris in there, it can cause this too.
    Keep us posted.
    Dan
SOURCE:
TASCAM DPO2,CHANNEL 1 WILL NOT RECORD, CHANNEL 2 STILL STILL RECORDS PROPERLY. ANY ADVICE?
Being older I recall these recorders. The problem with them was 8 track tapes never played very well due to the cinnamon roll design, the recorder and players tuck the tape back into the center of the roll when playing them. This poor design causes them to wear out fast and often snag or damage the mechanisms. Not to mention you can often hear adjacent tracks spilling over into the current track you are listening to...
In your case I think the recording head which records track two is out of allignment or contaminated with oxide from the tapes which tends to cake on them. You might try giving it a blast of compressed air if you can find the recording heads, or if unafraid cleaning the head witha q-tip in denatured alcohol or a commercial head cleaning solution for old magnetic tape machines, the solution is basically alcohol and something like freon to make it evaporate if I recall correctly.
If it still doesn't work it is probably because these things are very old regardles of how well they were made in addition to the fact the technology is 40+ years old.
Feb 08, 2014 | Tascam Dp-02cf Digital 8-track Recorder
How to record with Multi-effects feature on Tascam DP 01
I'm not familiar with the Tascam DP-01 but many multi-track recorders don't commit effects to the track until the mixdown phase. The thinking being that you cannot eliminate a "bad choice" effect once it's down to tape (old school term) and so they allow adding the audio tweaks at the final stages of recording. Here they hope you can appreciate the entire mix and then decide what sweetners to add.
Feb 21, 2013 | Tascam Audio Players & Recorders
My Tascam DP O2 not booting up
This needs to be sent to Teac in Montebello CA or at least call them and see what they advise.
http://www.teac.com/service_center/
Dec 27, 2012 | Tascam Dp-02cf Digital 8-track Recorder
Tried to play some old tapes back and could only hear the third track? any ideas
since it is cassete recorder,may be it has magnetize by your player the last time you play it and the result is erasure of 1st and secon track..maybe you should break the plastic cover 2 edge at the bottom of your favorite cassette tape
Mar 28, 2011 | Tascam Starter Pack for 4-Track Cassette...
My Tascam 244 at first attempt to play will not
This sounds like the drive belt has weakened with age. Will have to be replaced.
Feb 19, 2010 | Audio Players & Recorders
Tascam 238 tape deck
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Mar 21, 2008 | Tascam Audio Players & Recorders
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Tascam mf p-01 portastudio
hi sounds like a worng channel or no output from something check the tape output's for anything if there is sound but bad or low then the tape is the problem if it's good then check that the cable connection is good (connect it to a reciver) then if all is good till the unit: check that you are listening to the right channel check that your output device is good (headphones,speakers) (connect it to a reciver) good luck
Mar 30, 2006 | Lexicon Omega Desktop Computer Recording...
 Grubhead
Grubhead
Marvin
Marvin
