Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then f20 again moved it again to check the lines it worked for 5 loads then f20 again
    President:
  • Kenmore Master
  • 662 Answers
Http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
Posted on Jun 10, 2010
3 Suggested Answers
  • 662 Answers
SOURCE: f20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
agitateme
  • 88 Answers
SOURCE: i have a kenmore elite HE5t steam front load
I've seen this complaint 5-6 times within the last month. Try this. Remove the top panel by removing the three screws along the back and pushing the panel back and then lifting up. Locate the pressure sensor mounted on the right side of the machine. Check the pressure sensor hose very carefully for splits or cracks caused by chafing on the tub. You really need to look closely, it only takes a tiny pin hole. If damaged, replace hose and make sure the new hose is routed properly, not taped to the tub as some of the new ones have been for some reason.
Posted on Mar 28, 2010
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
Mar 26, 2010 | Kenmore Elite 45986 Front Load Washer
F20 message on washer kenmore elite HE5t
Feb 28, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
I have a knemore elite HE5T and keep getting the code F20?
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Kenmore Elite 45986 Front Load Washer Logo
530 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
