Question about Ovens
Indesit KD6C35W double oven main oven won't heat up after a power cut 24hrs ag. It was on cooking a meal and was just ready when power went off (all over the house).we dished the meal up and left the oven with the door open so it would cool down.when the power came back after about 5mins or so the fan came on (as it always does to cool down once you turn the heat off at the stat dial). Thought nothing of it. Went to cook again this evening and the damned thing wont get hot although the fan is working!
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
aborcass
  • 2651 Answers
SOURCE: The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Posted on Mar 01, 2008
Corster
  • 79 Answers
SOURCE: stove has no power ( kenmore )
Sounds like it could be one of a few things:
The Fuse - Check this first. Have you a electrical safety cut-off switch box? Check if the kitchen appliances switch has tripped.
The heater element - you'll be able to tell if there are any bulges or blows on the element.
The transformer - most appliances have a built-in power transformer. Yours may have overloaded.
The PCB - This would be just plain bad. It's the clever chip that controls everything and it's expensive to replace.
If you have a phone number on the appliance for a 5-year free parts warranty; I would take it out. Then you only pay about £90 for the service.
Posted on Jun 19, 2008
  • 57 Answers
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Posted on Aug 26, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
Oven cooked a meal then no power
Check your junction box circuit breaker for issues. This should be on a 220 outlet. Find out if your model has an internal safety switch. If you trouble shoot all areas, then time to call a repair person.
Mar 03, 2014 | DeLonghi Ovens
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Jan 03, 2010 | Neff U1721 Double circotherm Electric Oven
Indesit fde20 main oven wont heat up
Oct 23, 2009 | Ovens
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
