Question about Lexmark T630 Laser Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
  • 320 Answers
The printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
Posted on Jun 07, 2010
The printer recognizes tray 2 but it will not print to tray 2.
The printer will not print from any tray if tray one is pulled out. the paper path from any other tray still goes through tray 1\'s feed path (little slit in the front of the tray). if tray one is not in the printer it will not pull from any other lower tray.
Jun 03, 2014 | Lexmark T630 Laser Printer
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
Making a clicking noise when it prints.
Here is a great guide that you can follow to try to identify where the noise is coming from and try to fix it or have it fix.
http://bit.ly/dif9Ck
Feb 06, 2010 | Lexmark T630 Laser Printer
Problem with a T630 Lexmark the message "Change Tray 1 Plain Lett
i take it that the printer does not go to ready? does you printer stop with 64mb in the display? if it does change the network card. if this isnt the problem some more info would be great
Mar 27, 2009 | Lexmark T630 Laser Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Manual feed only
Pull out tray 1 & ensure the gray left-rear paper type clip is completely in the notched hole.
Aug 11, 2008 | Dell M5200n Laser Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Lexmark T630 Laser Printer Logo
427 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
