Question about Hotpoint RVM1625 Microwave Oven
Nu-tec NTV2131 51cm TV
When I turn my TV (Nu-tec NTV2131 51 cm) on, it comes up with a blue screen with a red lock displayed in the top left hand corner of the screen. I have tried pressing all the buttons an the remote but cannot get rid of the blue screen. As I turn the television off, the TV flashes onto a normal channel for a moment, then turns off. We have not set a parental lock code on the TV and cannot get the TV to prompt us for a code so we could try 0000 as a default.
Appreciate any advice you can provide
  • Mareka Oct 14, 2008
Press the 'display' button for 5 seconds
Posted on May 24, 2008
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
Oct 25, 2015 | In Microwave Ovens
NU-Tec 21"/51cm model NU2101N
It sounds like the main board is malfunctioning and needs to be replaced. Depending on the age of the tv, you may just want to replace it. Please post the make and model to help us better assist you.
Thank you for using Fixya and good luck
Apr 15, 2008 | Hotpoint RVM1625 Microwave Oven
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
Kenmore 721 microwave, no power
I have seen many of these - Hopefully you do not have security screws holding the cover on the main body of the microwave. If you do, then you will have to find a special Security Tipped Screwdriver to remove the cover screws - typical is a torx with a security pin in the center of the hole - you likely will not be able to remove them otherwise. If you do not security screws, then simply remove them from around the back and likely one on the left side and slide the cover off the back of the unit. There is a lip that locks the cover to the frame. Typically on top where the power cord enters, is a small circuit board with a fuse holder, with again typically an ABC20 Amp slo-blow fuse - if you can't find a 20 Amp you can likely go with a 25 Amp fuse - If you have a meter, check the fuse for continuity ( most times you can't see inside this fuse and a meter will tell you if the one you remove is good or not).
Watch your hands - plug the unit and see if you have a display - then that's it - slide the cover back on, it locks on along the top and both sides and put back the screws
May 13, 2014 | Kenmore 72129 Black Countertop Microwave...
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
The oven door goes down and up ok but does not close completely,leaving a gap of about a cm at top.i cant see any adjusters.Can you advise please?
The door swing hinges might have come out too far try and lift up and push in at the bottom other than maybe a lock switch for when you put it on self cleaning at the top ,Don't know
Apr 02, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
Delonghi
Changing bulb in DeLonghi ED 8525S-SBD
This is merely an account of how I fixed mine - do this at your own risk. The oven is full of high-voltage items which include large capacitors which are not discharged when you unplug it from the mains. You can still get a life-threatening shock from the charge which is stored in these components.
Therefore do not touch ANYTHING electrical except the bulb connectors.
1. Unplug the oven and place on a suitable surface 2. Remove the cover. This is held by five screws at the back of the of the machine. Three are along the top and are philips type and the other two are on the bottom left and bottom right corners and are star-grip. The cover must slide backwards first before coming off. 3. Find the bulb holder. It is located on the right of the oven as you look at it from the front. Turn the oven so that its right side faces you. The bulb holder is an oval black part with two electrical connections coming off it. It is about 6-7 cm long and 3 cm wide. It is mid way in the oven (from top to bottom) and a little towards the front. It is held to the oven frame with two bent metal prongs 4. Remove the electrical connectors by sliding them backwards. 5. Bend back the prongs and lift out the bulb holder. 6. The bulb in a 20W 240V oven lamp with a standard oven lamp screw-on fitting. 7. Replace the bulb. 8. Put the bulb holder back in place, bend the prongs back to secure it, re-connect the electricals. 9. Replace the cover and screws.
Jan 15, 2008 | Microwave Ovens
Hotpoint RVM1625 Microwave Oven Logo
303 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
