Question about Kenwood KDC-419 CD Player
How to check for blown fuse radio will not light up turn on
    President:
  • 2,317 Answers
There should be a fuse plugged into the back of the stereo, remove the fuse and check the element of the fuse for being broke in half. Also, check the fuse in the car that supplies power to the stereo.
Posted on May 17, 2010
2004 Pontiac Grand Am SE dash back lights quit working I installed an aftermarket radio. Wiring OK no blown fuses.Every thing else works fine plugged factory radio back in lights still did not work.
check that dimmer is turned up ---and check connections around where radio work was done for damaged disconnected line connector also check dash fuses not just fuses from radio --or your radio may not be compatible to your dimmer circuit -most oem radios display are Incorporated with dash functions and after market ones are not
Jul 23, 2015 | 2004 Pontiac Grand Am SE
Fuse box diagram for 2001 Volkswagen Passat
its quite easy to spot a blown fuse generally a blown fuse looks like this with the wire cut in the middle.
Mar 22, 2009 | 2001 Volkswagen Passat
How do you check fuse in the back of the radio?
1.Turn off the vehicle. Locate the main fuse box.
2.Locate a fuse box that isn't under the dashboard by checking under the hood of the car.
3.Look at the diagram on the inside of the fuse box's cover.
4.Determine if the fuse is blown by looking through the clear plastic casing.
5.Take the blown fuse to an electronics store or a car-parts store.Push the new fuse into the empty slot in the fuse box, making sure that it is in the same direction as the other fuses. It should slide in with a tight fit.Replace the fuse-box cover.
6.Complete the above steps before removing the car radio.Disconnect the car battery under the hood by disconnecting the cable from the negative terminal (the black cable) of the battery. Remove the dash area around the car radio.Unscrew the four screws on each corner of the car stereo.Locate the fuse on the back of the car radio.
7.Take the blown fuse to a car-parts store or electronics store to find a replacement fuse. Place the new fuse into the car radio.lide the car radio back into the dash opening. Replace the corner screws followed by the dash trim panels. Put any screws and clips back into place.Reconnect the car battery. Turn the car on, and if the blown fuse was the problem, the radio should work.
OBD diagnostic tool one stop supplier
Jun 03, 2014 | 2001 Volkswagen Beetle
Impala radio not working
did you check the fuse
Nov 28, 2013 | Cars & Trucks
Tribeca fuse
Blown fuse(fuses painel box).Blown hidden fuse (on the radio wiring,behind the radio)Bad grounded ground wire(s).
Oct 24, 2013 | Cars & Trucks
Dash lights not working
it can't be a fuse problem because the lights would not turn on at all if the fuse was blown.check the dimmer switch,i believe the problem has to be there.hope this info helps.take care and good luck, manny
Feb 19, 2010 | 2005 Toyota Corolla
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Jan 30, 2010 | 1997 Acura RL
No power to radio or interior lights.
i would say because the interior does not work as well that it is a blown fuse. you will have two supplies to the radio. one permanent fuse that holds the memory and an igition fuse which is live with ignition turned on. check the permanet supply fuses because the interior light will also work off one of them, same as radio. the fuse may look good you need to test across both sides of the fuse with a 12volt tester, it should work across both sides of the fuse.
Apr 22, 2009 | 1999 Dodge Avenger
Will the power light still come on if the fuse is blown?
To prove if the power light comes on with a blown fuse, just take the fuse out and turn it on.
If the light comes on your fuse could be blown. Replace it with the same rating. Let the guys at Radio Shack help out on that.
Fuse type: Radio shack 270-1062 or Equivalent.
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
Kenwood KDC-419 CD Player Logo
152 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
