Question about HP Photosmart C6180 All-In-One InkJet Printer
Hpqthb08.exe Problem Hi, I'm having the problem with the hpqthb08.exe showing up on startup. How can I fix this. Please I really need help. Thanks Nessa
Hi, I'm having the problem with the Hp Photosmart C6180 all in one problem: oxc19a0025 Ink system has failed. How can I fix this.. Thanks ls
Posted on Nov 25, 2008
,,^________^,,
  • 813 Answers
Hi friend
ur printr driver cd is corrpeted u have to need a new driver cd downlod driver form link & make a new cd
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=1153494&lang=en&
Posted on Mar 31, 2008
HP Photosmart Premier starts up at each boot up.
You can remove it from your start up menu by clicking start>run and type msconfig and press enter. click the start up tab and find hpqthb08.exe and uncheck the box next to it then click apply on the bottom of the window. That should fixya! :)
Feb 19, 2012 | Office Equipment & Supplies
I had a trojan virus on the computer after removing the virus each time I start up I get that notice that C:\Users\PETERG~1\AppData\Local\Temp\csrss.exe. can not be found how can I fix that problem
Hiya
please try this cc cleaner it should clean up any residue left behind in temp files and other places
its a free download
this may help you and please let us know if it done the job or not
http://www.piriform.com/CCLEANER
many thanks
Jul 08, 2011 | Computers & Internet
Hello i've got a problem with my computer anytime iswitch on a message appear : file not found "systeme32/drivers/prgds.exe". how can fix this proble ? Thanks
This is because your system was infected with a virus (prgds.exe) and the same virus was successfully removed from your system by the antivirus software. Now the path for the same virus file still exists in registry / windows startup list. As the virus file was removed and no more exists, you are getting this message. This is normal. no need to worry.
In Run prompt type the command "msconfig" and under the startup tab, uncheck the item which refers to this .exe file and restart your system. This will fix your problem.
Please rate the solution.
Thanks
Sep 18, 2010 | Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
Nov 24, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hpqthb08.exe is missing
Try using windows update, however, run it a few times it should update your system with the file.
Nov 11, 2008 | HP Compaq Presario SR1200NX (PN211AAR) PC...
Taskmgr.exe appears when computer is on
go to start type in msconfig go to startup then disable all apply reboot once k
Oct 07, 2008 | Microsoft Windows XP Home Edition
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Philips SPC 200NC Webcam
Explorer.exe won't load
hi, your OS is corrupted and may need re-installation. Before that, if you can load explorer.exe manually and see the desktop, then go for a system restore from the system tools to an earlier date. Also try to boot to the known good configuration from the boot menu.
thanks
Aug 14, 2008 | Microsoft Windows Vista Ultimate Edition
Make your system virus and spy ware free. Then unistall all the softwware you needed from HP CD or Web site. Hope this will solve your problem.
Feb 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
275 people viewed this question
Ben Johnson
