Question about Refrigerators
My side by side model GSS25IFRF bb will not dispense ice from the door. The light dims the water works but no ice comes out. Can you help?
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
aasc
  • 1606 Answers
SOURCE: Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Posted on Oct 10, 2009
57 varieties
  • 1653 Answers
SOURCE: No water from dispenser
As you have ICE then the most likely a fault with the water dispenser valve. It may also be a fault with the controller board. You can try resetting the Fridge Freezer by switching off the mains line power for approx 30 minutes and not opening the doors pr pressing any buttons during that time. Then turn the power back on and see if the fault has cleared. If not then you will need the valve or controller replaced.
Posted on Oct 15, 2009
aasc
  • 1606 Answers
SOURCE: Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on Mar 05, 2010
SOURCE: GSH25KGRE BB water dispenser not
I'm not sure what the problem is either but I have the same problem that KDNPGN has (same Model too)
Posted on Dec 06, 2010
Water and ice dispenser stopped working
You will need to replace the dispenser control board on the door. Here is the part to order.
Dec 08, 2012 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have a Ge fridge Model# Gss25ifrf bb that occaisionally starts beeping with no visable explanation
This is most likely an issue with one of the door switches. (located in the top of the inner liner at the front, where the door pushes it in when closed) (could be either the freezer or fresh foods door switch) The refrigerator thinks a door is open, and sets off the door alarm. This might also result in leaving the interior light(s) on, which could melt light covers or add to the work load of the refrig. Another possiblity could be the dispenser recess display (WR55X10444) but let's hope that's not the case, as it is a bit more expensive.
Aug 16, 2010 | GE Refrigerators
Mar 04, 2010 | GE Refrigerators
I have a GE GSS22JERF BB that started with failure to dispense ice and water with the lights dimming at every attempt. Now the Relay on the mother board is in a continuous trip mode and the compressor is...
You have a bad main control board ( motherboard ) . Replace this board , and it will fix your problem . You do not have a bad overload . The failure to dispense ice and water , with the lights dimming , is the give away of a bad board .
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Oct 15, 2009 | GE GSS20IEP Side by Side Refrigerator
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Jul 31, 2009 | Refrigerators
Water dispenser not working but ice maker does
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
