My washer only get a little water and my clothes dont get clean
  • 343 Answers
Could be blocked inlet hose/filter/connection. If water flow is ok to inlet valve on rear of machine, it's probably a faulty inlet valve. Replace valve with new unit......Good luck....Nomess
Posted on May 17, 2010
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Washer wont fill with water/clothes dont get clean
Actually the machine is working like it is designed. When the correct soap is used, these machines clean clothes better than the old style. Try using a major brand of soap like Tide, Bold, or Cheer. Make sure it has the HE design on the bottle. This means that it is made just for the new High Efficiency machines. Also make sure you don't use to much. Read the directions. If this is done correctly, I'm sure you will find that it does clean great. I was like you when I first saw one of these new machines. "These is no way you can clean dirty and I mean dirty clothes without enough water to cover them. Well since, I have became a believer. They have put a lot of thought into designing these things. They had to of, for them to clean as good as they do.
Please rate solution
Aug 27, 2009 | Whirlpool Duet WFW9550 Washer
Lint left on some items washed
Either the link came from another part of the clothing, or it is in the little bit of water that is under the tub or in the drain screen and gets washed back up when water fills.
Jul 05, 2009 | Washing Machines
Whirlpool duet front load washer doesn't get clothes clean.
A FEW THINGS TO TRY FIRST RUN YOUR WASHER EMPTY ON THE HOT WATER SETTING UNLESS YOU HAVE A CLEANING CYCLE THEN USE THAT THERES ALSO SOME NEW PRODUCTS OUT THAT YOU CAN USE TO CLEAN YOUR WASHER OUT BUT FIRST TRY THIS ITS FREE , ALSO CHECK YOUR DRAIN PUMP AND THE DRAIN PUMP FILTER TO MAKE SURE YOU DONT HAVE ANYTHING CLOGGED IN IT LIKE A SOCK AND LASTLY CHECK THE AGITATOR BELT TO MAKE SURE ITS NOT WORN SEND ME A UPDATE WE'LL GET IT FIXED DONT WORRY
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire uses way too little water
most front loads use less than 5 gals to wash or rinse since most of this is absorbed by the clothes little or no water will be seen during wash action..as long as clothes get clean don't sweat it just be sure to use low suds HE detergents just remember that's why you bought the front load to save water and energy
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Washer
Clean your water inlet filters, and refit carefully. Clean all inlet screens, ones in hose as well as machine inlet.
Mar 26, 2008 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
