Motorola Mobility RAZR V3 Logo
A
Anonymous Posted on May 14, 2010
Unable to charge..why? - Motorola Mobility RAZR V3
Anonymous
Level 2:
Novelist:
  • Expert 152 Answers
  • Posted on May 21, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
152
Questions
Helped
129655
Points
229
I had the same problem trying to charge with one of those "universal" chargers. Then I find the original Motorola charger and that solved the problem.
I hope this helps!
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on May 16, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2052884
Points
24677
Either your battery is nearing the end of its useful life or your charger is not charging it. If you are two years old ... the end is near.
2answers
Unable to charge tablet. Used several different cable. Red charging light only blinks maybe.
You may have to get it fixed. The same thing happened to me before. And I got it fixed.
Jawbone up wont charge
It may be the problem of the charger or the battery, please check them. If the battery is unable to charge or keep charge then replace it.
If the charger is unable to supply sufficient charge or no charge then replace it with a new one.
4helpful
3answers
Unable to charge W270 Motorola with Moto V3 Charger.
1helpful
Unable to charge
motherboard is weekplz go to the motorola service centre
2helpful
2answers
Motorola L6 charging?
get the right charger because that charger is not the right one okay
2answers
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 • Cell Phones
Unable to charge
You mobile software has some problem get it check with some one professional or claim they warrenty if it is there
1helpful
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
