Question about Insignia NS-L42Q-10A LCD TV
My insignia ns-l42q-10a just gave out yesterday. When I plug it in no light comes on at all. I already replaced the power board, and it didn't work at first, but then after a couple of days it came on. It only lasted for about 7 hours and went out again, I was wondering why it would come back on only to do the same thing it did the first time. Is there anything that can be done to fix the problem?
  • 3 Answers
If your NS-L42Q-10A will not power on with no lights and if you have a blue light on the tcon board when you push power then your problem is not your powerboard. The issue is your main board. These can be purchased from ShopJimmy and ebay.
Fixed one of these tvs today 8/17/12 using main board pn 715G3269-1 hope this helps someone out down the road.
Posted on Aug 17, 2012
    President:
  • Insignia Master
  • 749 Answers
There are two possibilities here.
The first is that you've had bad power board.
NS-L42Q-10A is known to have issues with the power board.
You can read more here:
http://blog.coppelltvrepair.com/2011/04/insignia-ns-l42q-10a-ns-l42x-10a-does.html
The second option is that you have a bad main board. This also not unheard of and since you were able to get it to work with another power board it is actually the more likely case.
What I'd do if I were you is try to heat the main board a bit with a dryer to see if it will start up more easily in that case.
Do not overheat it though.
Sometimes it's just bad capacitor that needs time/temperature to work good.
Other times it's bad solder, usually on the main microcontroller, which needs higher temperature which expands the metal until it makes good contact.
Other times it is something else.
Posted on Apr 13, 2011
5 Suggested Answers
John-INSG
  • 312 Answers
SOURCE: Insignia NS-L42Q-10A Setup: Wrong TV Source Chosen
You can change this option by going to the "Channels" menu and selecting "Auto Channel Search." Additional details can be foundat InsigniaProducts.com, under the Support tab for your TV.
Posted on Mar 10, 2010
Testimonial: "Thanks!"
  • 148 Answers
SOURCE: I need a power cord for Insignia NS-L42Q-10A tv?
Hi there, (as far as I know :P) all these tv/monitor cords are the same...you can even use the one from your home computer. If you have a homecomputer try that powercord, if that works. then thrifstores are full of these for around a dollar. Radioshack and the like will have them too, but it could run upto $20....You can also try computerparts stores...These cords are all over. I have an old crt monitor of wich the power cord fits into my 2008 32" lcd tv....
Good luck and if this has (or not) helped you, then please rate, thank you!
Posted on Feb 03, 2010
John-INSG
  • 312 Answers
SOURCE: INSIGNIA REMOTE CONTROL FOR SAMSUNG THEATER SYSTEM
Because you want to control a Samsung device with an Insignia TV remote control, Samsung will have to supply a code for our product. You may be able to find technical support via Samsung's website.
Posted on Mar 05, 2010
eagle338
  • 4889 Answers
SOURCE: I need to know how to enter insignia ns-l42q-10a
Did you try "Input , 2,5,8,0" ? May I know what exactly is the problem?
Caution:Be advised that the service menu is to be accessed only by trained professionals. Keep a notepad handy. If you accidentally change some setting then pen it down go back and change it again. Pen down the values of anything that you may wanna change. Be very careful.
Posted on Jul 08, 2010
Hello My name is Chris and I have 7 Insignia Model NS-L42Q-10A with white wash ?
The Tcon Board or the LCD panel is faulty. Can confirm by Replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 21, 2016 | Insignia Televison & Video
I have insignia ns-l42q-10a, I have backlight but no picture and no sound. Wall outlet is good. I was watching football game when the picture was lost and about 10 seconds later the sound went dead
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 08, 2015 | Insignia NS-L42Q-10A LCD TV
Where is the fuse located
It can be located at its main power input section itself. Might be on power regulator board, of before the power filter board.
Dec 03, 2013 | Insignia NS-L42Q-10A LCD TV
Insignia ns l42q 10a white screen
Absence of video signal. The main digital board should be troubleshooted. Contact any service technician. This is not a user repairable fault. google.com/+GopakumarGopalan
Dec 01, 2013 | Insignia Televison & Video
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
How does Insignia TV turn on
THE MAIN BOARD, usually is a 3vdc-3.3vdc signal to turn on the power supply
Feb 01, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
I need to know how to enter insignia ns-l42q-10a service mode. Thanks meetyahya
Jul 08, 2010 | Insignia NS-L42Q-10A LCD TV
Mar 09, 2010 | Insignia NS-L42Q-10A LCD TV
I need a power cord for Insignia NS-L42Q-10A tv? Are they available, and where?
Feb 03, 2010 | Insignia NS-L42Q-10A LCD TV
Insignia NS-L42Q-10A LCD TV Logo
578 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
