Question about Kenmore 23822 Top Load Washer
Doesn't agitate It no long agigates the wash.
  • Anonymous Mar 21, 2014
    only agitates 1 direction
  • 714 Answers
Check your motor coupling!
Posted on May 16, 2010
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Tip
How to fix a Washing Machine if it Doesn?t Agitate
If your washer fills with water but doesn’t agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.)
1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn’t, the belt may be loose or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) There may be a problem with the controls, or the agitator solenoid may be broken. Call a repairperson.
on Sep 03, 2010 | Washing Machines
Machine doesn't agitate
You need to repair the agitator. Here is the kit to order.
Below is a video to show you how to make the repair.
Nov 12, 2012 | Estate TAWS850PQ
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Washing machine doesn't agitate correctly it just spins around
You will need to have the washer transmission replaced, that is about theonly thing that would cause this.
Feb 01, 2012 | Whirlpool Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Final agitation and spin do not happen, timer does not stop
check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Nov 20, 2006 | GE WBSE2090A Top Load Washer
Kenmore 23822 Top Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
