Question about Garden
Kubota ztr will not start safety start system? Diesel not a fuel or battery problem ignition switch will 'power up' but starter won't engage.
SOURCE: NOTE NOT PATHFINDER: TERRANO II 2.7TDI
i have been through the same problem with mine. trust me if this is happening to you it is eitha the battery or the alternator. do not service!!!!!!!!!!!1 its awaste of money if this is your problem.
Posted on Jan 04, 2009
  • 1201 Answers
SOURCE: wont start
There's only 2 more things that I can think of, check the fuse for the ignition, then the computor itself, you did everything else.It might be the problem and may not.
Posted on Jan 28, 2009
SOURCE: FARMTRAC 665 DTC
Try changing the ignition switch.
Posted on Apr 20, 2009
wadembly
  • 475 Answers
SOURCE: Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Posted on Jun 08, 2009
  • 85 Answers
SOURCE: Dixon ZTR buzzes but won't start.
Clean the battery connections to bsre metal
Posted on Aug 07, 2009
Finding repair parts for Kubota Z122RKW ztr mower
kubota service agents spares
kubota web site spares
local mower shops that service kubota products
May 18, 2017 | Kubota Garden
WE have a dixon husqvarna ztr mower model 966004101. It wont turn the starter over. We purchased a new battery wasnt sure if it was something to do with safety switch
Just had this problem. When you turn the key all the way over to start does it at least turn over like the battery is dead or do nothing at all? If nothing at all the solinoid is bad. Mine is a speedztr 42". Mine for 2 years was draining my battery and I had to leave trickle charge on it year round. This year when I tried to start completely dead although battery tested 12.37. Found the ignition switch was bad and replaced it and solenoid. 12.00 each at local hardware store. Starts and runs like a dream with No trickle charger! I would start with solonid if your battery is not being drained every week.
Apr 12, 2017 | Husqvarna Garden
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
Location of fuses
most fuses are near the back of the switch if there good and its not starting check the safety switches
Apr 27, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
