Screen size How to resize my screen my screen has reduced automatically without fitting to my desktop...its viewed only in the middle now..what should i do?
  • minishy Apr 02, 2008
    No changing the screen resolution does not fix my problem..
  • alan07 Jul 04, 2008
    my screen has gone to the left how do i get it back to default changing the resolution is not helping
  • 813 Answers
What the ur screen reslution
u have to do this right click on desktop
go properties>setting > screen resloution>chnge it do 1024by 768 pixes
Posted on Mar 31, 2008
  • sandip panchal
    sandip panchal Apr 02, 2008
    ok then
    try to manu button on ur montior there was size position option on there set ur montier display size & posistion
    or ur montior deflaction coli are week change ur difalaction coil u have chage it with a good tecnision u have cost of 50$ or 100$ try do it
Downloaded pictures from my iPhone to my computer are in an oversized format that must be resized to be viewed, then saved. What is wrong?
Photos taken in very high resolution are very large physically. Thus, when viewing them, especially with a default photo viewer, they are often too large and must be resized to view. If you check the viewer settings, there may be an option for "shrink to fit" and "enlarge to fit" that allows smaller and larger pictures to be viewed full screen without manually resizing and resaving each one. If the viewer you have doesn't have this feature, search sites like DOWNLOAD.COM to find one that does. There are many out there and many of them are free.
Oct 04, 2015 | Cameras
Chrome loading too large to fit my window
on your main screen click right and priority and parameter
screen resolution choose size resolution
moving the harrow to tune the size !!
Sep 05, 2014 | Google Chrome
Icons on windows desktop
You can resize the icons on your desktop as follows:
right click anywhere on the desktop and select view and then you will have the option to select different sizes for your icons.
Hope this helps.
May 06, 2014 | Computers & Internet
I bought a computer with 15.4 Wide XGA display. It has not arrived yet. I want to put photos in. I believe the wide XGA will distort the photos. Can I make the view normal?
The size of the screen and its shape has no importance if you use a decent imaging program like IrfanView - in it the image will be resized to fit the screen and if the shape doesn't matches the screen will have black bands to compensate.
The only time a distortion will be encountered is when you will try to use it as a desktop background in the Stretch format - just select Center and all will be fixed. Of course the best solution is to crop and resize the picture to fit the screen exactly - you can do that with Irfan.
Aug 10, 2011 | Fujitsu LifeBook V700 Notebook 15.4...
I'm using Windows XP Professional. My computer
Quick fix: Do a system restore to yesterday or whenever they last good restore date is.
We could mess around with the settings for quite a while, but I'm not really sure what has happened. Unless you clicked in the lower right hand corner of your web browser (which I assume to be Internet Explorer) and reduced the size to something waaaaay less than 100%.
Jan 14, 2010 | Dell Computers & Internet
How do I move my screen image a few pixels to the left?
TV - analogue (S-Video, composite) X X X TV - analogue (component) X X VGA (with EDID) X X VGA (without EDID) X Digital (DVI, DisplayPort, or HDMI) X X Digital (HDTV via DVI, DisplayPort, or HDMI) X X LVDS (notebook display) X If the feature is supported, the corresponding tab is available on the Adjust Desktop Size and Position page. If only one feature is supported, then only the controls for that feature appear on the page and there are no other tabs.
Scaling The scaling controls let you adjust the size of the desktop to best fit your screen. The configuration that you specify may be overridden by the settings in the Resize section.
Select a scaling mode
Aspect ratio: This setting expands the desktop as much as possible while maintaining the same dimensional proportions, or aspect ratio, as the original image. There may be some black borders, but you may prefer this setting to avoid distorting the image.
Full-screen: This setting stretches the desktop to fill the entire display screen.
No scaling: This setting leaves the display image in its original size and centres it on your screen resulting in a small though crisp image. A black border may appear around the display image.
Perform Scaling on
GPU: This causes the GPU to scale the desktop from the set resolution up to the native resolution timing.
Automatic: This setting uses a combination of display and GPU scaling to scale the desktop from the set resolution up to the native resolution timing.
Override the scaling mode set by games and programs
When this check box is checked, applications cannot change the scaling mode set on this page.
Preview
Under the Preview section you can select a resolution and refresh rate, and then the preview image shows how full-screen applications will appear on the screen, using the selected scaling configuration. The available refresh rates will depend on the scaling method selected.
Resize Some displays, such as HDTVs, extend the edges of the display beyond the visible borders of the screen. This overscan is intended to hide broadcast data that is not intended for the viewer. This results in hiding useful parts of the screen for non-broadcast content, such as the Windows desktop.
The best way to resize the screen in order to view the entire content is to use the controls provided by the display hardware.
The resize controls on the NVIDIA Control Panel are provided in case satisfactory results cannot be achieved using the controls on the display.
Position Use the arrow buttons in the image under Adjust the desktop position to adjust the position of your desktop or image on your screen.
Aug 17, 2017 | Samsung SyncMaster 940BE 19" LCD Monitor
FILE TOO LARGE TO OPEN
Dear lambrini
The image you are trying to view is very big. Please reduce the size of the image. (Dimensions width and height)
Also another possibilty is that actual size of the image is too big. for example an uncompressed BMP image can easily be 2,3,5 Mbytes in size (if this is the case please compress to JPEG,or GIF format first)
Phones have limitations to the above two things and cannot handle very difficult tasks.
Regards
TIP: If you want to use this image as a desktop for your phone resize at only 128x 160 pixels, (or 28 x 35 mm) which is your screen resolution.
The phone is capable to squize larger pictures automatically to this size but the speed of the phone may be affected as it has to do that continously.
Mar 30, 2008 | Motorola Mobility W375 Cellular Phone
Printing photos
That is called pixelation and is usually the result of enlarging a photo, whether it be resized larger on the computer or printed at a larger size than it's original pixel dimensions.
Check your printer settings for a setting like "resize photo to fit paper" and uncheck it. Or print from a photo that is larger than the paper and it will reduce the size without any pixelation.
With digital photos you can always go smaller than the original, but rarely ever larger.
Feb 17, 2008 | Epson CX8400 All-In-One InkJet Printer
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
