Question about InFocus ScreenPlay 4805 Multimedia Projector
After replace lamp projector stop working no picture. If there a way to reset the projector even if you got no picture.
    Problem Solver:
  • 11 Answers
Make sure all the covers are on tight because they have little switches on them so people dont get a zap.
Posted on May 17, 2010
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Hi
Is it projecting light though? can you get a screen lit up? check connection from projector to your computer make sure its intact, try another cable if possible.
Hope this helps
Mar 26, 2010 | InFocus ScreenPlay 4805 Multimedia...
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | NEC NP60 Projector
NEC VT 480, replaced new lamp ,still low brightness.
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
Sep 11, 2009 | NEC VT595 LCD Projector
My projector suddenly stopped working
The instruction manual says that to reset the timer you have to hold down (simultaneously) the Menu button, then Enter button and the Down arrow...then press the Standby/On button on the projector. This worked the first time I replaced the bulb, but now that I've had to replace it again, its not working. Good Luck.
Mar 21, 2009 | Sharp DT-100 Multimedia Projector
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
140 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
