Question about Kenmore 98702 Stacked Washer/Dryer
Not spinning the water out of drum - Kenmore 98702 Stacked Washer/Dryer
  • Kenmore Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinenot spinning the water out of drum - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
WATER WILL NOT DRAIN OUT OF THE BARREL DURING SPIN
I'm not sure of your model, but most are the same design. The water is pumped in, but centrifugal force through the spin should force it out. If I am understanding you correctly in that your drum is spinning (I assume slowly if full of water). It is likely you have a clog in your drain hose area. If the drum is not really spinning, check for a "click" when you open, then close the lid. A switch could keep the drum from spinning.
I hope this helps... Good luck!
Sep 15, 2009 | Washing Machines
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
131 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
