WILL NOT WORK OR TERN ON - Washing Machines
  • kmuranaka Nov 10, 2008
    drum does not turn. Just moves back and forth about 2 inches. This happened before and tech had to replace the motor rotor. Could this be the same problem ?
  • 185 Answers
Make and model number please
Posted on Mar 31, 2008
What is the postcode for tern path glenrothes
Since I live in the United States I really don't know but a Google search came up with this.
Tern Path, Glenrothes Postcode KY7 6TN
KY7 6TN Postcode Information
Postcode for Tern Path is KY7 6TN
Town for Tern Path is Glenrothes
County for Tern Path is Fife
Longitude for Tern Path is -3.1802191
Latitude for Tern Path is 56.2145598
Morse code for KY7 6TN is Kilo Yankee Seven Six Tango November
Sep 16, 2014 | GPS
No power
switched mode power supply and class d amps, take to shop that can work on these, it should of had a 5 year warranty.
Mar 30, 2014 | Peavey XR 1212 Powered Mixer Mixer Powered
Printer error message
What specific problem are you having?
Mar 13, 2014 | HP Officejet Pro 8600
My 98 dodge caravan i replaced the starter and the van wants to turn but it doesnt and all the eletrical is still working. what could be wrong?
you could have a hydro lock preventing it from terning is the starter good ive had lotsof bad starters directly from the part store check the bat you need 12v and enough amps to tern it over the next thing is check for a good ground if you have a ground thats weak it wont tern over properly
Jul 22, 2012 | 1998 Dodge Caravan
2005 rendezvous wont start
TRANSLATION TO ENGLISH IS:
Battery is in good shape, it has gas, fuses check good in center console fuse center and in front of hood, wen i tern the key i can hair relays clicking but ignition wont tern or start ,check starter and its good. OK then do you have a "security" light on in the dash cluster?
Jun 14, 2012 | 2005 Buick Rendezvous
Starter terns but will not tern motor
Most motorcycles have an internal one-way clutch. It is in the oil and consists of several metal barrels that grab on to a smooth drum on the side of a large gear. If the smooth part of the drum becomes chattered the barrels will no longer grab so the starter spins, but the motor does not turn over. What you need is a one-way clutch and the starter gear it rubs against.
May 11, 2010 | Motorcycles
The left turn signal stopped working, then the right. Now the blower and the abs light is on. I changed the turn signal switch/hazzerd/wipers. And the 10 amp fuse keeps blowing. Marked turn/bu/abs
20amp turn on four ways and parking lights go around replace any bad bulbs turn of for ways tern key on tern right tern on go around se if blinking tern on left and se if not chang flash thears 2 flashers switch the tow to se witch is bade.chek fuse for the right amp look inside fuse cover for right amp
Jan 26, 2010 | 2000 Dodge Caravan
Cover display not tern on
fix your front panel, the display might be broken. try to use the phone from the inside panel. if it works, do what i tell you.
good luck
Feb 15, 2008 | Nokia 9500 Communicator
Washing Machines Logo
Top Washing Machines Experts
