Question about Sega Master System Console
Sega master system 2 setup - can't get picture
Hi guys,
I have a sega master system 2 console with all cables, ie. power, rx and tv switch, control pad. Everything is plugged in and switched on, however I am having difficulty finding the right channel on the tv. I am getting no sound or picture, no matter which channel or AV it is set on. I have tried multiple channel scans and tunings, to no avail. I would really appreciate some guidance!
Thanks
Stephanie.
  • steffie1 Apr 06, 2008
    Yes, faulty equipment is always a possibility. Unfortunately I have no electrical expertise whatsoever, so I have no way of checking these individual items. Any ideas on how I can check each wire/component, or do you know anyone who can check these for me?
    Thanks
    Stephanie.
  • Jonty McIn May 14, 2009
    can't tune my sms 2 into the samsung TV
    New Friend:
Most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Posted on Jun 12, 2010
    New Friend:
As TVs get newer and newer they support less and less old technology.
Your best bet is to dig around for (and I don't even know if such an item exists) a set of AV cables for the didn't support AV afaik without a hack internally. Best get a cheap VCR (even one that doesn't work) and use it as AV converter for newer TV.
So new TV's are now basically monitors in that they have no VHF/UHF tuners
Posted on Mar 02, 2010
  • 167 Answers
I had that problem too, it was the rf box inside the unit
Posted on Jun 28, 2008
The cords might be falty the anntenna box that is not working or the cables might be a bit lose inside and might be in the wrong persition.
Posted on Apr 03, 2008
SOURCE:
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Good luck and game on!
Jul 26, 2010 | Sega Master System Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Have just bought a hardly used sega megasystem 2 console but it doesnt seem to work. does anyone know where all the leads etc should go? thanks
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts www.gameoz.com.au stock the a huge range.
Mar 20, 2010 | Sega Master System Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Jul 27, 2008 | Sega Master System Console
Bad signal on my sms 2
i had the same problem, don't use rf, use an ave cable you can find them on ebay
Apr 03, 2008 | Sega Master System Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Sega Master System Console Logo
4,136 people viewed this question
Top Sega Video Game Consoles & Games Experts
Karl Roche
Karl Roche
tamaracrum
Level 1 Expert
Ekse
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
