Question about Lakewood LAK792SGSA Utility Heater
LAK792SGSA Utility Heater: how many watts? What are the dimensions?...
How many watts? What are the dimensions?
    President:
  • 1,015 Answers
This heater is 1500 watts. It's dimensions are 8 1/4 X 6 1/4 X 14 1/4. It comes in a steel case and is gray in color. Here is the company website http://www.lakewoodeng.com/Category.aspx?cid=1066
It appears that they have filed bankruptcy and now no longer make heaters...just fans.
Posted on May 16, 2010
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I have a 3VE53 heater and was wondering about how much eletricity does it use if I keep it at 65-70 degrees for 9 hrs. a day?
Okay, for example a 100 watt bulb left on for 10hrs uses 100x10 =1000. so 1000= 1kwh. so look at the watt rating on the fan motor and times that by 9hrsand then do the math, then look at your bill and see what you pay per kwh (kilowatt per hour) and times that with your answer, for example lets say the heater blower is 10watts, take 10 X 9 = 90, then 90 divided into 1000=.09 so it .09 of a kilo watt almost a tenth of a kilo watt. so if you pay 3.25 a kwh then you would say .06X3.25=.195 less than one cent, hope this helps
Feb 16, 2012 | Dayton 3VE53 Oil Filled Liquid Fuel...
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
Need to know amp draw for 1VNY1 radiant heater.
on "high" these can draw as much as 1800 watts (or 15 amps.
If there are many other loads on the same circuit, the breaker is likely to trip.
Jan 29, 2010 | Patton Electric Patton PUH680-U Electric...
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Heater coils on a aloha utility heater lights up
It is typical for the elements to glow. The glowing is caused from the high amount of electrical flow through the coils. It is the same principal of how some light bulbs work.
Feb 17, 2009 | Patton PUH680-U Utility Heater
A ? about watts my heater pulls
Look at the plate on the side and calculate Voltage (110 typically) times amps (what ever it says on the plate) gives you watts.
Dec 07, 2007 | Reddy R155D Utility Heater
Lakewood LAK792SGSA Utility Heater Logo
261 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
