Question about Hotpoint Ultima WF860 Front Load Washer
Clothes & washing machine covered in a white & clear gel.
After washing had finished all the inside of the machine is covered in a gel substance. Also washing powder is not completely being dispensed in drawer. Water is going in ok. Any Ideas?
  • 1462 Answers
SOURCE: Machine stops in Rinse & Spin Cycle & leaks water
suspect problem is that water is not draining fast enough so when machine gets to spin there is too much water present which gets thrown up thro thew soap drawer. check the filter. on many hotpoint filter is not obvious. at back, take off bottom panel. you will see a large dia hose going from bottom of machine to pump. undo this hose at the tub end and the filter is inside it. be carefull. if you havn\'t managed to drain, a lot of water will come out. if this doesn\'t work, get back to me if you want
Posted on May 26, 2007
gittos73
  • 244 Answers
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Posted on Aug 22, 2007
jason0110
  • 66 Answers
SOURCE: Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Posted on Sep 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Posted on Dec 28, 2008
cbgarner
  • 138 Answers
SOURCE: white residue om dark clothes
Even if you use liquid detergent, if you put too many clothes in the washer, or too much detergent. It has happened to me before.
Posted on May 21, 2009
Washer won't advance, have already replaced the timer. We can manually advance it but that was the whole reason for replacing the part. Lid switch is fine, will fill with proper water level, will spin and...
Hi iv acidently washed a poise pad in the washing machine ,,the pad broke open and a gel like substance is all through clothes is this toxic,,is it silicone?? what if we wear cloths will it be absorb in blood system if we wear them im stressed as gel filled whole washing machine,,and dont know if clothes are safe to wear,,i cant find any info on wether poise gel in pads is dangerous plz help arrgghh
Feb 08, 2014 | Washing Machines
My housemate washed two garments in my WT540 AQUARIUS HOTPOINT MACHINE and now water is stuck in the drum and not moving. The door is locked. How do I wash out the water so I can get those two garment
something has blocked the pump I susspect, turn off the machine!!! there should be a small cover or door at the base of the machine, have a baking tray and large towel ready to collect the water, open the pump cover place the tray as close as possible and if you have a small tube inside then remove the plug and drain the water to the tray.if its just the screw cap then unscrew the cap behind the cover anti clockwise, water may begin to empty so be ready to either screw the cap back in or replace the stopper as the water in the machine will fill the tray several times, when all the water is empty check the pump is clear by looking into the hole the water flowed from, remove any obstrustion ( if you have the tube you will also have a screw cap to access the pump filter) when obstuction is cleared, screw caps back in and put stopper in, switch the machine on and select a spin cycle,let it finish and end, this should sort it out.
Dec 06, 2013 | Hotpoint Aquarius WD63 Front Load...
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
White residue on black clothing
I am sure you did not wash dark clothes with white, right?
How old is the washing machine?
Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
What type of soaps are you using?-- any chance they could be causing the residue?
How hard is your water? (Do you have a water softener in the water system?
Please tell us more about your circumstances.
Mack B
Dec 28, 2010 | Washing Machines
Water level in washer
The basket floats. The washer relies on a circulation pump to wash the clothes. THEORY OF OPERATION PAGE 22
let me know
May 08, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
LAUNDRY SMELLS BAD
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
Dec 30, 2009 | Bosch WFL 2063 Front Load Washer
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
Clothes coming out spotted
Hi Residue builds up inside of washing machines for all sorts of reasons. Many detergents and fabric softeners can leave filmy layers behind. Hard water can cause spotting on both plastic and metal thus ending up with spots on your washing, how to resolve this follow the instructions, 1, use vinegar a bottle and place your machine on the hottest wash cycle and let it run through a full cycle, when finished use a paper towel with vinegar to clean the inside, set machine on a rinse cycle, this may need to be repeated but will solve it, also use gels and liquids instead of powders and descale etc.
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WF860 doesn't clean the clothes at all!
Lack of water in wash cycles. possibly due to blocked filters in water valves where hoses connect to machine or faulty water valve, normally cold inlet is the main problem
Mar 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
348 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
