Question about Ovens
De Dietrich oven not working!
Hi,my de dietrich oven, suddenly, has stopped working. The grill works fine and when i switch the oven on the fan seems to work but there is no heat-do you think it is the element and is it easy to fit?? Many thanks Vicky.
  • 3 more comments
  • LindyH May 03, 2008
    De Dietrich DOD328 oven has stopped working. The grill and fan appear to work but the oven does not heat up. I have never mastered the timer and wondered if 'misuse' of these buttons has affected the oven as everything else appears to be in good working order?
  • Carol Williams May 07, 2008
    My De Dietrich oven stopped working - regardless of which setting you have it on, it fails to heat up past warm to touch. I also have a problem in that the oven came with the house, and the manual is in French, and my French isnt good. I suspect I have also fiddled with the controls, and probably caused the problem myself.
  • garyhodes Sep 06, 2008
    We have exactly the same problem. We would get it fixed, except the oven takes around 45minutes to heat up and even then doesn't go above 200o, so we think there is something fundamentally wrong with it. Have had repair people out twice, who said we weren't using it properly, but we are.....
  • Anonymous Nov 27, 2008
    Have a UME 41 De Dietrich. Stopped suddenly to heat, eventhough Grill and fan and light are fine. Settings on timer are just as usual. Just strange. Anyone knows which part is involved?
  • mrssam Apr 19, 2009
    I have exactly the same problem - when this first started, the main fuse for the house tripped - now the oven appears normal, just doesn't get hot.
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Posted on Jun 30, 2010
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Hot air blowing out at the top of De Dietrich oven, just after putting on new oven seal, fan seems ok what could it be.
Pending on the location of the oven (i.e. not where the seal is) it could be natural ventilation of the oven. Many ovens have ventilation underneath the stovetop.
Sep 02, 2015 | De Dietrich Ovens
Unlock control panel
Function switch must be in the "O" position
Press the " /\ " button for a few seconds until it beeps.
Then use the +/- buttons to set time.
Try powering off and switching back on again if that doesn't work.
May vary between models but De Deitrich do free manuals downloads. Just google it
Nov 10, 2014 | De Dietrich Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
N Serie: 04-09-01097 Ref DOD 348XXG11 Type E248H1 52106 The above are the details of my De Dietrich oven. My fan has stopped working and I need a new seal for the main oven door and for the...
We don't offer service engineers. Look in yellow pages or ask your oven supplier for a contact. Most Domestic Appliance companies can help you.
Sep 25, 2017 | De Dietrich Ovens
My de dietrich oven is not heating. the light and fan are ok
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 28, 2011 | De Dietrich Ovens
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Ovens Logo
1,792 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
