Question about Goodman CKL36AR36 Air Conditioner
Not cooling, water is leaking around the outside unit. plus ice has formed around hose on the unit outside. goodman model number gsh130421ac.
    Champion:
  • 225 Answers
Take a garden hose and wash the unit real good,if the unit outside cant breath this will cause it to freeze up
Posted on May 16, 2010
I have a maytag dual cool side by side fridge, recently the ice maker has reduced ice production and the ice cubes are not fully formed ( Almost hollow). When you use the water despenser it makes a...
It sounds like you have a water flow problem. I would inspect the unit for ice building up in or around the freezer fan motor. If the ice is forming in side the freezer, the trouble could the a restriction in the fill tube. But this does not affect the water dispenser. The noise you hear could be the water line moving when water flows through the line, or your water valve itself could be the problem, like the valve shutters when in use.
The valve is easy to check, its located behind the unit in the back left corner. Remove the screw holding the valve in place, while dispensing water hold the valve and see if the issue is only the valve. If the valve is the issue this could cause both problems you have. Part number 67005154
Water Valve
Good Luck
Aug 21, 2011 | Maytag Refrigerators
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
A/c wasn't cooling.ice formed on outside lines.had a/c tech check freon level,and was low. he added 3 lbs. cooled for 1 day,now its not as cool .
You have a freon LEAK!!! They need to find the leak and FIX it for you...
Call them back and make them fix it right or call another company to fix it right for you.
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 16, 2010 | Goodman CKL60AR60 Air Conditioner
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER IS LEAKING ON INSIDE SHLEVES OF REFRIGERATOR & THEN TURNING TO ICE. I DON'T HAVE AN ICE MAKER water is collecting on left side only
This is due to your fridge not cooling correctly. When the temp drops low enough, condensation forms. When the cooling picks back up, it freezes. Make sure there is nothing blocking the door. Also check the weather strip around the door to ensure it's seated properly. Over time, these strips become wore out and out of of shape causing air to leak.
Nov 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
My goodman aircondition system takes forever to cool
You can have one of two problems .... firstly ,the condenser ,i.e outside part of the unit could be dirty or inefficient in loosing the excess heat or secondly ,the gas (freon) in the system have leaked out ...if it is the second ,the thinner line of the two leaving the condensing unit will start to get ice forming on it .... let me know if this helps
May 22, 2009 | Goodman Heating & Cooling
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Goodman CKL36AR36 Air Conditioner Logo
263 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
