Question about Hoover Washing Machines
Model no VHD9143 Machine has stopped witgout spinning and am unable to open the door.
Called an engineer
Posted on Apr 01, 2008
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Can not open the door
if there is still water in the machine the door will not open try and spin it out again and check pump filter
May 27, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
I have a Whirlpool Gold Ultimate II dryer. When the door is opened on the dryer, the light does not come on and the clothes do not stop spinning. I think there is something wrong w/ the swich inside the...
This video will show you step by step how to replace the door switch It does indeed sound to me as well that your stop on and the door switch is the problem
GENE
Sep 05, 2011 | Dryers
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
