Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
CHANGE CHANNEL TO ADD WII TO IT
How do you change the channel so we connect the Wii to the router
    President:
  • 1,768 Answers
Your issue is with the Wii wireless setup not the Netgear.
Please follow the wireless setup from Wii manual.
Posted on May 17, 2010
Error code 204038
Error Code: 204038
The Wii console was unable to connect to the Wii Shop Channel.
  • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
    • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
    • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • There could be a temporary network issue with Nintendo's servers. Please wait a few hours and try to access the Internet Channel again.
  • If the above steps did not resolve your issue, please call 1-800-255-3700 for assistance.
Jan 26, 2014 | Nintendo Wii Console
I cannot connect my Wii to the internet. Is there a part that I need to connect, or is there something else that I need to do in order to get the wireless connection working?
Here is a step by step instruction on how to connect your Nintendo Wii to the internet. Please note that connecting the Wii to the internet does require a wireless connection, or wireless router for a signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
copy and past this into your internet browser.. if you should receive an error for any reason, here directions and a link to solve it.
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 03, 2011 | Nintendo Wii Console
How to get wirless internet
Turn on your Wii.
  • 3Select Wii Options, which is located on the bottom left of the screen. This is the button with the Wii logo.
  • 4Select Wii Settings.
  • 5Click forward to the second menu screen using the blue arrow to the right.
  • 6Select Internet.
  • 7Select Connection Settings.
  • 8Choose an open connection, indicated by the word: "none".
  • 9Choose a wireless connection.
  • 10Determine the best option for you: Manual configuration or Search for an Access Point.
  • 11On Search for an Access Point, your Wii will search for a wireless network to connect to and will display a list of available networks. Networks identified with a closed padlock require authentication to join.
  • 12Select your network.
    • If your connection signal appears yellow or red, the stability or strength of the connection is not strong enough for the Wii's Internet needs. If possible, remove any obstacles between the Wii console and the Access Point or change the channel on your router to avoid interference.
    • If your wireless access point does not show up when you choose, Search for An Access Point, your router may have Broadcasting set to "No" or "Disable." Some routers also refer to this security as "Stealth" mode. You can either change your broadcast setting to "Yes" or "Enable," or you can manually enter the SSID in the manual setup screen of your Wii console.
  • 13Select Save and OK.
  • 14Select OK on the next screen and the Wii will preform an automatic connection test.
  • 15Wait for the Wii to connect and download any needed updates.
  • Browsing the Internet
    1. 1Go to the Wii shop channel and download the Internet Channel. This channel is free.
    2. 2Select the Internet channel from the block on the main screen and follow the instructions to browse the Internet. Feel free to go on any site you want, like Facebook or Twitter. (or maybe even this website!)
    Aug 19, 2011 | Nintendo Wii Console
    My wii is not picking up my wi fi conetion and it said that my error code was 52232. It said to visit this website for assistance, so if you can send me some helpful facts that would be great!!
    The Wii is not connecting or finding your wifi because of a firewall issue with your wireless router. Your wireless router is set to broadcast on channel 6. The Wii wants a certain channel though. I had this same issue when I set up my Wii.
    Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6.
    The following link will give you a default settings page for each brand of routers. Select your brand and model and it will give you a url to get to the settings. The information you need is found in the "Broadcast Channel:" area.
    http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
    Jun 10, 2011 | Nintendo Wii Console
    Wont let my wii on my wifi error code 50200
    Jun 09, 2011 | Nintendo Video Game Consoles & Games
    CANT CONNECT TO CALL OF DUTY BLACK OPS ON THE WII KEEPS SAYING UNABLE TO CONNECT TO SERVER?
    You can try to change the channel on your router to either 1 or 11. How you do this depends on your router model.
    Also make sure your network settings are correct on the Wii by running a test or trying to connect to the Wii Shop channel. If these work Call of Duty should work as well.
    Feb 27, 2011 | Linksys Wireless-G WRT54G Router
    What is error code 209600
    To solve this error :
    This error is caused by an issue with the Wii console being unable to connect to your wired router.
    Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
    Log on to your router by using the default IP address and check if MAC filtering is on or enabled, which is usually under Security. If MAC filtering is on or enabled, add the Wii console's MAC address as an approved MAC address.
    Oct 24, 2010 | Nintendo Wii Console
    To change the settings on the router, you will need to open the set up page of the router. On this page you will find all the settings of the router. Do you have any computer connected to the router ? If not then you will need to connect the computer to the router. OPen the set up page on the wired computer and change the settings of the router.
    Click here for more information about the router
    Mar 26, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
    Keep losing conection from wii to my belkin router
    It's a wireless interference problem. To resolve that, you must change the router's wireless channel by logging in to the router's admin page http://192.168.2.1 you can change it under the Wireless tab. Set the channel to 11 and save the changes. Try to power cycle the router after that.
    May 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Games wont play
    you need to reset your internet connection...
    so just pair your router and wii up again
    thanks
    Apr 06, 2009 | Nintendo Wii Console
    NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
    291 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
