Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
We have a 3020 john deere gas we just had head redone new head gasket put back together and only getting oil to half the rocker arms. Took rocker arm assy back off and made sure holes were clear put back together still oil to only half the rocker arms.
    Problem Solver:
  • 6 Answers
You might go ahead and put a manual oil gauge in place of your oil sending unit..back side of eng block r/h side.. check you pressure,needs to be between 15 to 25 psi at low ideal,with the eng at at operating temp.The head oils from the back main to the back camshaft bearing to a port at the R/H back part of the eng block to the head.Go ahead and pour some oil on the rocker arm assemble and let the tractor run a bit work it up to high ideal.If it doesnts oil possible problem with the head gasket being ported wrong are back cam bearing,
Posted on May 18, 2010
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: We have a 3020 john deere gas we just had head
A couple of things should be looked at.
1. Make sure head gasket is aligned properly and not blocking any ports on the head or block. 2. When the head was milled debris may have been pushed into a port blocking flow, check for blockage. 3. When you replaced the head, did you torque the bolts in the proper sequence and to the specified ft/lbs?
Posted on Mar 26, 2010
1998 Bronco 11 xlt oil gauge fluctuation from low to half way, put in 50 weight racing oil tappets are noisy . radiator was flushed and new put in the reservoir is bubbling ,
first off did you change the oil pump? if you didnt it could just be the 50 W is too thick and thats why you are hearing the rocker arms,but sounds like its getting too hot i need more info the bubbling in the radiator is an indication it could be blown head gasket etc need more info!!
Jul 21, 2017 | Cars & Trucks
What is the proper sequence for the head bolts on a deisel 3020
the head bolt torque is 130 +or- 5ftlbs and as far as sequence if not sure start in the middle of the head and work your way out alternating side to side and in an X. Step up to 130 by starting at 80-100-115-130.
Nov 09, 2013 | John Deere 3010,3020 Tractor Basic...
My john deere 4020 tractor rocker arm assembly only gets oil two half of the rocker arms and the other half doesnt
Have you put another manual oil pressure gauge on the engine to see what the pressure is ? And at the same time does it change with engine load or rpm's ?
Feb 22, 2013 | Garden
2004 Cavalier broken rocker arms after head gasket repair.
Rocker arm issues are common in that car. They can happen without any reason. This is not going to be cheap to look at. When the head was repaired it had to be removed. The timing chain might not have been properly tensioned. That would cause the timing chain to slip and then you have pistons slapping valves and spark plugs. This cause rocker arms and pushrods to bend or break and also can damage pistons.
May 03, 2017 | 2004 Chevrolet Cavalier
Low oil pressure due to oil-caked particles falling into oil flow of head
His fault. He should have used a vacuum to collect the gasket pieces while he was cleaning the gasket surface. The engine will have to be well flushed, including clearing all of the oil flow passages.
Aug 01, 2017 | 2002 Nissan Xterra
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
We have a 3020 john deere gas we just had head redone new head gasket put back together and only getting oil to half the rocker arms. took rocker arm assy back off and made sure holes were clear put back...
Mar 26, 2010 | John Deere 3010,3020 Tractor Basic...
John deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Apr 13, 2009 | John Deere 3010,3020 Tractor Basic...
1993 TOYOTA TERCEL 1500cc Valve Seals Replaced now smokes much worse
You either have had the wrong valve seals installed, they are physically missing, or the valves are incorrect (too loose in the guides/stem too thin). The rocker arm seals will not contribute to your issue. If it did not have the oil smoke before you took the head off, the issue is with whatever the machine shop did. Valve seals have to fit TIGHT, or oil will go down the valve stem into the intake.
Take the head back to the machine shop & tell them to fix it. For free.
Aug 23, 2008 | 1993 Toyota Tercel
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
194 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
