Question about Logitech X-530 Computer Speakers
I have a 2 pin computer connection but the speakers have a 3 pin connector . How do i connect to the pc
  • 40 Answers
You need to connect all the tree of them using the adapter you got in the package, i have a 2 pin computer connection but the - flo210_4.jpg
Posted on Dec 24, 2010
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
Feb 12, 2011 | Vizio 42 in. LCD TV
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
How do I plug the Power Button wire into the motherboard?
Printed on the MB
HD LED +1 -3
PWR LED +2 -4
RESET 5- 7+ (Why the changed order? & there's no reset button on this computer.)
PWR ON +6 -8
There are nine pins with a little triangle pointing at one and a 2 next to another.
The pins on the MB look like this:
2ndpin
1st pin
Found some info on the 506GR. Unfortunately Gateway is keeping the service manual a big secret.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | Computers & Internet
Green light next to power button stays on - no response from computer, totally frozen for up to 12 hrs, then green light goes off, computer suddenly comes on for 5-10 min then freezes again.
Good day sir, hi, You need a thorough check on your PC.
But first try testing the Motherboard, Processor and Memory module.
As this point you need a friend, that knows how to tinker with your PC
Or you may need to do this.
1. memory testing:
Try replacing a new memory ram module on your PC, get the modules out of the memory slot, and let it be tested on another PC. if good,
2. power supply
Test for the power supply box, remove the 20/24 pin power connector from the mainboard and short the green and any black wire, your fan should blow out air.
3. Test for motherboard.
remove all coonections from the motherboard, except the 20/24 pin power connector, and the 12v 4-pin molex power connector, connect the pc speaker or the thumb speaker on the speaker port, connect a keyboard, clear the CMOS, (or remove the battery temporarily), connect the header panel (power switch, reset, power led) place the processor and memory (the tested good one). power on.
You should hear a beep (good) The keyboard will light up the three leds, then a few seconds, the numlock led.
If you hear 1 long and 2 or 3 short beeps, problem with the display section. Reseat any graphics card. test again.
If you hear continous beeps, reseat the memory, if the beeping persist, replace your motherboard.
If you hear nothing? only fan blowing, replace your motherboard.
I can only give you instructions, you need a someone who knows how to service a PC.
Dec 17, 2009 | Compaq Presario 5000 PC Desktop
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Logitech X-530 Computer Speakers Logo
109 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
