Question about Carrier 38CKC030 Air Conditioner
Looking for evaporator coil cd5axa036017abaa . Three years of recharging rather then fixing now the coil is out of warranty and Carrier and service company will not stand behind product.
  • calvin flanagan May 16, 2010
    whats size coil do you need
2 Suggested Answers
  • 415 Answers
SOURCE: looking for evaporator coil cd5axa036017abaa
It is unfortunate that Carrier is failing to stand behind their unit. Are you getting this information from the local Carrier Distributor or from the Carrier Syracuse Plant? If you have not done so already, try contacting the Carrier Syracuse Plant......be sure to obtain ALL records from your service company to accompany your letter to Carrier. They will need specific installation, start-up, and all service dates to include specifically the type of work performed and the materials used. Your dealer should provide to you at your request.
If it doesn't pan out, then look into service companies and products in your area that have a better reputation and warranty offer. You can install a coil from a different manufacturer than the outdoor A/C unit. It simply needs to be matched up. If your unit has been leaking for 3 years, you have been paying extra utility costs due to poor performance. You have also exposed your entire system to moisture which, if not properly dealt with, will lead to problems with your compressor and/or metering devices. A reputable company will help you address these concerns at time of coil replacement by removing the refrigerant in your system, testing for acid, installing a filter drier, evacuating the system down to 500 microns, and recharge using virgin refrigerant.
Here is link to a site giving you Carrier's C.E.O.'s name and contact information. Hope this helps. :-)
Posted on Mar 26, 2010
Recharge air conditioner
Two tubes go to the evaporator coil in the dash. One is larger than the other. Follow it to the compressor and you'll find the port. OR, look on the accumulator. Next time tell us year, make, model
Aug 17, 2017 | Cars & Trucks
How do i get my soleus air conding unit to blow cold air, its blowing cool air. can i recharge this unit myself -if so then what type of freon would i use.
most likely have to install a line tap valve to charge. look for oil residue on lines to indicate leak. the evaporator is the weak point on most a/c systems.
Jul 05, 2014 | Soleus KY-25U Air Conditioner
I have an aruf036-00a-1a and have been told the evaporator coil is leaking. The unit is approximately 7 years old. Do I need to buy the whole box with blower and all or can I just purchase the evaporator...
The evaporator coil can be purchased separately and is the most common part to leak on an a/c system. The system must be evacuated of refrigerant and the old coil cut out and the new installed. Leak check performed and vacuum pulled on the system before recharging with refrigerant.
Jun 26, 2011 | Goodman Heating & Cooling
Model # 25372055201 When you turn on Air
Hello, clean the evaporator coil with a coil cleaner spray that you can buy at any heating and cooling store, if cleaning the coil does not help looks like the unit has a low refrigerant charge and will need to be recharged. A quick test you can do is measure the air entering the evaporator coil and leaving th evaporator with a thermometer, find the differance, it should be 15-20 degrees on a normal working ac. If it is below 15 the unit is umdercharged.
Jun 09, 2011 | Kenmore Single Room Air Conditioner
Compresser freezing up
not enough airflow over evaporator coil or low on charge. Give more details for better answer.
Oct 05, 2010 | Heating & Cooling
Looking for evaporator coil cd5axa036017abaa . three years of recharging rather then fixing now the coil is out of warranty and Carrier and service company will not stand behind product.
Hi, if you have a leak in the evaporator coil which this happens a lot and they came out and didn't try to make any attempts in finding and repairing the leak or they found it in the coil and didn't order a new one, this is against the law by E.P.A standards. They must make every attempt in making the repairs if it means replacing the coil, no if, ands, or buts!! Keep your receipts on them charging the system. Now that its out of warranty, I would call them and bring this up about not changing out the coil when the leak was found. I am sure they used dye to locate it.I have found more leaks in the evaporator coils then I care to count, and had to replace the coil. This is something you can't do on your own I must say, as it takes special equipment to do this job. I would call the Enviormental protection agency and tell Carrier you will do this, and report them. I bet they will stand behind it then. You have to get tough with them. I am a air conditioning contractor and know the law. The E. P. A. will get them on the ball trust me. This is bull+)_(*&%!* !! Don't let Carrier walk on you, this coil should have been put in the schedule to be changed out right away, not to continue to charge it to get you through. This is a 3 ton split system. Stay on them, this will be covered if you make the call and stay on them. The E. P. A. are very strict on this as this is why they have stopped us from venting freon into the air, they have very strict guide lines we must follow and Carrier did not follow them on your unit. Please keep me posted, and the best to you.
Sincerely,
Shastalaker7
Mar 26, 2010 | Carrier 38CKC030 Air Conditioner
Refrigator not cooling coils clean and compressor working
check defrost timer control on older located on bottom by the condenser coils look at elect diagram to see if one is hook up
Sep 24, 2009 | GE Refrigerators
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
Mold related illness looking for a mold unfriendly a/c
be sure to leave room between filter and coil for installation of a uv light. hepa filtration may not be as effective as a micron filter. some hepa filters are glorified pleated filters. i use april air filter cases with replaceable cartridge inserts for filtration down to 3 microns. filters are 42.50 a piece to replace cartridges, no moving parts and the coil will be immaculate 10 years from now even if you empty the vac in the return every week . they are that good. the cartridge lasts a year under normal use. i have never in 15 years had a mold and or mildew problem on a unit with an april air filter, the uv light is a great accessory but probably not needed in 90 percent of the applications unless you are going for doctors office where proceedures will be performed, etc. good luck
Dec 06, 2008 | Alen AMS09 Split System Air Conditioner
Can I replace a damaged evaporator coil?
Well, the old screwdriver through the evap trick huh?. you planned on repling evap coil and recharging with 134 a? correct??if you have that knowledge and ability then installing a charging port would be least of issue. sorry for sarcasm but not a do-it-yourself fix honestly bring it down to a local repair guy
Feb 29, 2008 | Haier HBF05EBSS Commercial Beverage...
Carrier 38CKC030 Air Conditioner Logo
173 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
