Question about Garden
Engine starts and runs,mows for 30 min then chokes
Engine starts and runsmows for 30 min then chokes out-wait 30 min will start and run 15 mins chokes out again next day will start and process repeats. Have put gas stablizer in tank but didnt seem to help. Engine is not excessively hot nor does it smoke. Engine is 16hp -10 year old craftsman riding lawnmower
    Sergeant:
    Champion:
  • 229 Answers
I had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
Posted on May 16, 2010
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Lawnmower shuts off after 15-20 mins of running
Sounds like a bad coil to me ... it only makes sense that has the heat from the engine transfers into the coil the coil windings expand and causes a open resulting in ignition failure and no spark to the plugs... if you need parts try www.partstree.com
Aug 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
Mower runs for 10-15 mins. then shuts off.
Check your gas cap. There must be a vent for the gas to flow joedog
Feb 26, 2009 | John Deere Garden
Mower runs for 10-15 mins. ands shuts off
I had the same problem on my craftsman 18.5 hp, the problem was in the choke, the spring was broken, and the choke was not free, replaced the spring and it is fine now. Check it out. Good luck.
Garden Logo
259 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
