Question about ASK Proxima DP6860 Plus Multimedia Projector
Multiple reddish pink vertical lines going from
I have a Proxima DP6860 media projector. When we first fired it up there was one pink line on my left side of the picture. Now the pinkish red lines go almost 2/3's of the way across the picture (vertical). Would apprecitae any help with this. Bought this on e-bay no idea how old it is.
Tengo mucha experiencia en reparacion de proyectores, hay dos cosas que pueden ser: 1- que tengas dañado un LCD ó
2- debes ingresar al menu de servicio donde existe una opcion para corregir el ghosting, esto puede corregir la falla. Lamentablemente no recuerdo como acceder al service menu. Espero alguien que lo recuerde o sepa nos lo haga saber. Saludos y Suerte.
Posted on Jun 09, 2010
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
Posted on May 26, 2010
  • patrick reagan Jun 10, 2010
    i'm glad you speaka his language
2 Suggested Answers
Basti
  • 1447 Answers
SOURCE: multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Posted on Mar 26, 2010
How do i flip the image on a proxima 6860...the image is upside down.
it's been a long time since I worked on one of these,but if you select the menu and look thru the settings, you should see "ceiling" with a checked box next to it. just uncheck the box.
Aug 07, 2010 | ASK Proxima DP6860 Plus Multimedia...
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
May 11, 2010 | InFocus Proxima DP6155 Multimedia...
Can the bulb out of Proxima DP6860 work in a DP6850?
No they will not interchange.
The DP6860 takes a bulb number LAMP-030 and is a 250 watt bulb.
The DP6850 takes a bulb number LAMP-017 and is a 190 watt bulb.
If you could physically make them fit by some means, likely just the wattage difference would cause problems with the projector. These bulbs require much more electronics to light up than what a normal household bulb does. I'm assuming the projector would think the lamp is either burned out or worst case cause damage to the power supply in the projector.
Mar 30, 2010 | ASK Proxima DP6860 Plus Multimedia...
Hi
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
I have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
What are these lines?
This is a LCD projector, one of your LCD Panels is blown, This is a $400 repair.
Jan 22, 2008 | Hitachi CP-X980 Multimedia Projector
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
ASK Proxima DP6860 Plus Multimedia Projector Logo
669 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
