Leaky machine Slow leak! Water leaking from bottom of machine still works and pump still pumps water out but water leaking from somewhere!
  • 185 Answers
Check the pump and your hoses
Posted on Mar 31, 2008
SOURCE:
Its leaking
Suspect a leaky pump
Feb 12, 2016 | Washing Machines
Washer leaks a little water when I put in a full load in it. Also leaks bleach when poured into dispenser. This is a top loader
Do you now where the leak is coming from? You may have to remove the outside sheet metal to observe the motor and tub. More than likely, the leak may be caused by a faulty pump or a seal in the pump.
If the machine overfills, you can get water on the floor as well, but you would notice that the machine appears too full.
The leaky bleach dispenser probably just needs to be removed, inspected and thoroughly cleaned. Water gets pumped thru it and any clog or problem with the pathway the water follows can cause overflow or a leak. BUT deal with the water problem first, that's the most important. A leaky pump will only get worse.
Also check the hose connections on the back of the washer. Old and cracked rubber washers can allow water to leak.
Sep 25, 2015 | Kenmore Washing Machines
Water runs out at the bottom of the front cover of the machine and doesn't spin properly?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jan 17, 2013 | Washing Machines
Why is there is water underneath my washing machine when I have not done laundry recently?
could be leaking at the mix valve,, or one of the inlet hoses are leaking.
remove the panel and investigate the source of the leak.
c...
Feb 06, 2011 | Whirlpool Washing Machines
Water leaking under machine
More than likely you have a cracked water pump.
Apr 08, 2010 | Whirlpool LSN1000LW Top Load Washer
Leaks out bottom somewhere
Hi, Check the pump. Sometimes they under the base. Your belts will be wet if the pump is leaking. Also check the dain hose outside the machine. Put water in ans then put it in the spin cyclw. You should be able to see where the water is coming from.
I hope this helps you. If I can assist you further, please let me know
Vic
May 23, 2009 | Washing Machines
Antifreeze leak
Ok, Its defiantly the seal that is between the water pump and the engine block that is leaking the coolant.
Apr 08, 2009 | 1993 Honda Accord
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
