Color registration problem for Oki Data C9500
Magenta registration on Oki Data C9500 printer is out by a 1/8 of an inch - I've reset the registration a few times - nothing is working - help please....
Brain-storm .... simple solution .... REPLACED Magenta Drum.... works as good as usual, but is still and always been out a little - very strange, depending on the stock, if I'm using a 10pt coated stock, color registration has always been a little out ( when the cyan and magenta are being used ((together)) - purple - dark blue etc ...)
Posted on Mar 31, 2008
Oki data c9500 job offset home error
Where the paper exits the printer you will see 3 black sensor arms hanging down. 1 is the exit sensor and the other 2 are job offset sensors. On of those 2 will be stuck. Just gently free it and all should be well.
Jul 16, 2017 | OKI Office Equipment & Supplies
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Registration error 3
n
2 = Yellow
3 = Magenta
4 = Cyan
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
OKI C5100 alignment issues, I think
FROM YOUR USEWR MANUAL>>>>>>>
In colour menu
AJUST REGISTRATION, press EXECUTE
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Dec 19, 2008 | OKI C5100n Laser Printer
Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Feb 15, 2008 | OKI C9500dxn Led Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Sep 04, 2007 | OKI C9500dxn Led Printer
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
