Question about Finis Swi MP3 Player
I can only get sound out one side - Finis Swi MP3 Player
    Problem Solver:
  • 9 Answers
Buy more headphones because there must be a slight fault in it
Posted on May 17, 2010
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Sound comes in strong and weak at different times
It could be that or a loose wire to one side of the speakers in the set. If it does it often enough locate where the actual sound for each side of the set is located---when it does it get close and listen---if one side is low or distorted you know it is either a connection or speaker on that side OR since most sets have a left and right channel for sound--the issue is in one side.(circuit problem)
Dec 05, 2012 | Vizio VF550M 55 in. LCD HDTV
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
No sound comming from the left side speakers in my 04 Envoy XUV.
Did you try your balance control on the radio? You will find FADE, and BAL. The balance will move the sound from side to side. If thats not it, it sounds as thought one of the harnesses behind the radio came loose. Hope that helps
Feb 15, 2009 | 2004 GMC Envoy
Tv sound only from right side
If you have the wires connected properly for stereo sound, go into the setup for the TV and set it for stereo speakers.
Feb 05, 2009 | Cambridge Soundworks TVWorks 250 Speaker
Sound only one side
uninstall the driver of your sound card if it is separate and reinstall it again, if the problem is goes again, the faulty part is your speaker, reconnect the cable again that goes at the back of your pc
Jan 14, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Thumping sound
does it sound like a metallic sound or somthing different
Aug 20, 2008 | 1991 Chevrolet S-10 Blazer
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Finis Swi MP3 Player Logo
54 people viewed this question
Top Finis Audio Players & Recorders Experts
Are you a Finis Audio Player and Recorder Expert? Answer questions, earn points and help others
