Question about Home
My jacuzzi hot tub control panel reads 3 straight lines and nothing works. I turned the power off at the breaker and turned it back on a few minutes later. The control read 356 then changed to 8.8.8. Then changed to- - - . Can you help?
Just installed new topside panel,control transformer and temp sensor on my jacuzzi tub. turned power on and i hear a cllick sound from the control panel and i get 4 dashed lines on the screen
sounds like a circuit breaker. im sure by now you have double checked your work? make sure all your connections are tight. check any inline fuses or for a tripped curcuit. often times these things are so simple that you miss them completely, im guilty of that myself.
Nov 17, 2016 | Jacuzzi Home
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Do I have the correct controller for my Hot Tub? I have a Jacuzzi Lexus L.C. with a Balboa F1089R1A processor. I ordered a topside control panel online and received a Balboa VL701S but nothing is working...
Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Nov 13, 2013 | Jacuzzi Home
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Just turned oh hot tub....it is reading cool....want it to heat??? what do i do? Caldera Hawaii model
turn the temperature up on the topside panel. if it is wired 220v then it will get to 104 deg in about 3 hrs
Oct 12, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
My jacuzzi stopped turning on.
I would check all power to the tub. Is it plugged straight to a breaker, plugged into a GFCI, GFCI breaker in the master panel? For it to just stop altogether I would think something tripped.
Oct 21, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
163 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
