Question about LG LHD45EL Dehumidifier
Will it cost me ?
I have a Sears Dehumidfier model 580-54701700 that ices up I have a tec checking it out he thinks its a sensor that controls the gas valve that defrosts the coil but he is not sure he ohmed the sensor and its 6 ohms and only goes to 7 ohms. What else could be the problem ? Is there a number that I could call to talk to some one ?thanks Todd
  • LG Master
  • 43,501 Answers
Dehumidifierswill it cost me ? - 2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 12, 2010
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
Jul 28, 2012 | Danby Dehumidifiers
The humidity control stopped working. The unit does run at 100% only
Hi and welcome to FixYa, I am Kelly.
You can get a new sensor here:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=119126
or
http://www.repairclinic.com/Kenmore-Dehumidifier-Model-58054501400-ID-698984-Parts
Thermistor PN: 6877A30013R other diagrams it is called a sensor assembly
Here is something to consider.... changing this part SHOULD fix the dehumidfier. However, if there is a problem on the control board it can give you the impression the sensor assembly is bad. 85% of the time it is the sensor that has failed.
Thanks for choosing FixYa,
Kelly
Jul 29, 2011 | Kenmore 54501 Dehumidifier
Dehumidfier runs, collects little water, the coils freeze up and water leaks out
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
Jun 23, 2011 | Kenmore 53509 Dehumidifier
MODEL DM 162EBS. Why is it when I switch my dehumidfier on 10 minutes later it goes to defrost. [ WHY?]
Let's think thru the dehumidification process--
A dehumidifer needs to create a COLD surface, on which to condense the moisture in the room.
If your room is quite cool, it is esily possible that the COLD surface can go below freezing-- Now the water is trapped in the ice-- So-- it has to defrost, to melt off the ice, and start all over again!
Can you move the Dehumidifier to a warmer spot-- maybe near a radiator, or a heat register? -- You will remove much more moisture in that way, too..
Just a question: Most homes are WAY TO DRY during the winter months-- are you sure you need to dehumidify your living area? (Maybe you are drying the basement?-- or a wet area?)
Just seeing if I can help
Mack B
Jan 20, 2011 | Dehumidifiers
MY DEHUMIDFIER DOES NOT PRODUCT WATER. SOMETIMES THE COMPRESS KICKS IN BUT LATER I ONLY HEAR THE FAN RUNNING. IS THE COMPRESSOR BAD? SHOULD I GET A NEW DEHUMIDIFIER?
Since this one is faulty, maybe you should go ahead and get another dehumidifier because trying to fix this one will cost you a lot of money.
Dehumidifier repairs are quite expensive. |So you get a new one straight away.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Unit is repeatedly freezing up
Almost all dehumidifiers now have automatic defrost, but if you are seeing frost is just one small area, it means there is a refrigerant leak. Check your warranty to see if the sealed system is covered longer than one year. Generally, if it is, most manufacturers will replace the unit (rather than repair it, as the repair is rather expensive compared to the cost of a new unit). If you do not have any sealed system warranty coverage left on it, don't fix it. Buy a new dehumidifier.
May 20, 2009 | Whirlpool 75-Pint Dehumidifier
I have a Kenmore 54701 dehumidfier, less than 2 year old. the power is on, a fan seems to be running, I no longer hear a compressor turn and, and no water is collected?
The sealed system of the Kenmore 54701 dehumidifier is warranted (Parts & Labor) by Sears for five (5) years. Since the fan in your unit runs but the compressor doesn't, I suggest that you return it to Sears and request (demand) a new replacement unit under their warranty. I say "demand" because Sears will undoubtedly tell you that the problem is due to some "other" component which is not covered, and will charge you mega-bucks to repair it. Been there - - done that.
FYI, read the (very low) customer reviews of these units on Sears website and you'll see you're not alone in your experience with Sears' inferior quality units.
Above all, do NOT pay to have it repaired. That money is better spent on the purchase of a far more reliable brand of dehumidifier - - (which will most likely cost less that what you paid for the Sears unit).
Mar 09, 2009 | Kenmore 54701 Dehumidifier
LG LHD45EL Dehumidifier Logo
119 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
