Question about RTO Basement Watchdog Sump Pump
The alarm for the basement watchdog keeps going off saying pump activated check main pump for failure how do I fix it?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: basement watchdog charger does not stop charging.
The charger is controlled by an electronic controller...that would be the most likely problem and the reason for it not shutting down IF the battery is good.
My first reaction is that the battery will prove to be the problem though.
If you need more info and testing the best place to call will be to call the service department at 1-800-991-0466
heatman101
Posted on Apr 06, 2011
My flotec E100ELT Intellishield pump control will not start unless I unplug power cord from pump control then replug to activate pump and high water alarm does not sound.
pump works fine..when plug in directly..sensor unit does not work all the time and is flooding the basement..how can i resolve this...where can i get just the sensor replaced
Jan 31, 2013 | Flotec 1 HP Electronic Sump Pump E100ELT
Alarm goes of a night for no reason
The water in the battery might me low. This usually happens in winter when the heat goes on and the air gets dryer. The battery water evaporates faster, but is still very slow out that tiny vent hole in each cell cap. The battery reaches the threshold, and the alram starts to trigger. If this is the case, simply add distilled water to all the cells to the bottom of the fill tube. Don't splash, the sulfuric acid is nasty. Hav baking soda handy to pour on sills, but don't get it it the battery.
Nov 04, 2012 | RTO Basement Watchdog Sump Pump
Watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Battery has liquid on top
The battery is charging with trickle charger. The liquid could be just water from condensation from the recharging process. If the charging is too vigorous, then it can also be sulfuric acid, so rubber gloves are in order. Clean up liquid with gloves on and paper towels. Once dry carefully remove caps and check water level. refill battery with distilled water to top of cell. Check water level at least twice a year. Wear safety glasses too.
Oct 03, 2010 | RTO Basement Watchdog Sump Pump
The alarm continues to sound. The red light for battery is on. I did add water and it went off for a very short time m, but then continued. I added more water, definitely full, and it continues to...
(Batteries may be substituted by using a deep cycle marine battery with the same specifications as described above, but the battery fluid sensor option will not function. Simply connect the battery fluid sensor to the positive terminal of the battery to disarm battery fluid sensor alarm).
Aug 05, 2010 | RTO Basement Watchdog Sump Pump
Pump continues to make noise as if its cavitating when there is no water to pump.
If there is no water to pump then it is cavitating. It should turn off when the sump is emptied down and the float drops onto the switch arm
Oct 21, 2009 | RTO Basement Watchdog Sump Pump
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
RTO Basement Watchdog  Sump Pump Logo
323 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
