Question about Dishwashers
Blocked up dishwasher?
I was naughty a couple of times and put washing powder in my dishwasher, now it doesnt work and says e3 on it but i have lost the manual so cant read what this means?
Your an idiot
Posted on Apr 20, 2008
  • 185 Answers
Make and model number please
Posted on Mar 31, 2008
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
I have a Kenmore builtin dishwasher model 17533200 , when I run it it doesnt seem to use the detergent even though the cleaner compartment opens.
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing a large pan in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels , and tablets sold by Finish Corporation and Cascade work better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Nov 18, 2011 | Kenmore 24 in. 17533 Built-in Dishwasher
Gritty murky crockery powder dispenser has sticky powder after the wash still in it.
Is it the dispenser that has murky powder or the dishwasher?
Dispenser: Is the dispenser being blocked from opening all the way during the wash load? This can happen in some dishwashers if a tall pan or dish is blocking the dispenser from fully opening. Hence, part of the detergent stays inside the dispenser and is goopy/murky/yuckie.
White powder on racks, nonstick spatulas, silverware basket: There has been a recent change in dishwasher formulation that can cause a white residue to deposit. Phosphates have been all but removed from dishwasher detergent. If there is a white residue on the dishwasher racks, etc, try a dishwasher cleaner such as Affresh for dishwashers and then look to consumer union for a new formulation. Be of good cheer: phosphates are very bad for our waterways, fish and fauna. This change was made in laundry detergent about 16 yrs ago.
Oct 11, 2011 | Dishwashers
I have a whirlpool washing machine WI4818S which isnt draining. I have checked the hose where the water drains out but that doesnt seem to be blocked there. also when i start the machine up, it doesnt...
Check the water pump, it may be completely dirty, washing powder. Too much washing powder.
By reducing the plastic tube goes into hydrostat. Wyjmnij powder tray, put the washing machine on one side of the plastic pull out the exact reduction and Purge this branch of the sludge and other particles.
S?uchaj Zapis fonetyczny
May 06, 2011 | Washing Machines
The powder dispenser on my ls 610a dishwasher does not seem to work properly. There is always powder left in the dispenser and the dishes are not always washed properly.
Try to make sure that the path for water isn't blocked to the dispenser. Ours will do that too if we forget to leave some space for the streaming water to hit the little tray.
Dec 23, 2009 | Ariston Technologies LL64WNA Built-in...
Soap block not releasing while washing
I urge you to only use Electrosol or Cascade powder with your (or any) dishwasher. Most ultra-cheap powder will not clean effectivly. If the dispenser does not open with the powder inside, a service call is the next step.
If you reply, please tell me the Make and model of your dishwasher.Good Luck!
Mar 23, 2009 | LG Dishwashers
Lost manual, wheres rince aid comp
forget the built in rinse aid, it only works for a couple minutes during the whole wash cycle. go out and buy the rinse/aid or jet/dry package that hangs on the racks and works during the whole cycle. of course use only cascade powder soap and sparingly.
May 27, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher problem
sounds like a blocked pump or pump line is blocked. you will need to check these and also clean out the spinners. not using a dishwasher can do more damage to them as there is long periods for the systems to dry. this cause a build up of food particles. using a cleaning agent for the dishwasher can help stop the build up.
Jun 15, 2017 | Dishwashers
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
