Question about LG Audio Players & Recorders
LG MP3 MF-FM12 - Manual
Hi, I need help with my LG MP3.
The problem is that when I want to put music there said no more free space, and it doesn't have any!!
The only thing doest it has inside is one DAT FILE that I tried but I coudn't delete. The name of the file is SETTINGS.DAT (4K).
I dont have the manual with me because I am travelling rigth now.
Thanks in advance for your help
SOURCE:
SOURCE: Incorrect Format Please Reformat the Player
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Posted on May 20, 2008
  • 116 Answers
SOURCE: how to format raw sandisk
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Posted on Sep 21, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sony Psych and Mp3 file manager
You need to reformat the player.
Posted on Dec 16, 2008
SOURCE: HOW DO I ADD MUSIC TO MY ''SONY NW-E015F''? (digital music player
you must use the program sonicstage.
thats the only way. you can find it in the cd that comes with the device , i guess you can find it in google too.
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Deleting files is not creating free space on my coby mp705-8g mp3
Ok First, Open Your MP3 player
2) Go To Setup
3) Then Go to system
4)Then Usb Mode
5) there will be auto or MSC
6) choose msc and then plug it in the files will be there.
Posted on Apr 13, 2009
Dear sir, whenever I try to download music to my HTC wildfire it says your track is downloading but it doesn't do anything. It then says I don't have enough storage space but I have a 2gb SD card...
Erase unnecessary data on you phone memory,even you have a lot of space on you SD card,still the phone memory need to maintain enough memory to perform or play the music,check your phone memory free space and save at 2MB and for sure it will gonna play the music.
Aug 07, 2011 | HTC Wildfire Cell Phone
Hi, I have a cortex DJ Mix 300 but only some of the songs on my ipod are being picked up on the database when I load it up. It doesn't seem to make a difference whether the files are MPEG or other...
There are different digital formats and some are not compatible to transfer file names... It is frustrating isn't it?... run into this all the time. To fix the probllem you would probablly have to buy a music editing software packaage that you could edit the files and put them all in the compatible mode.
Aug 06, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
I have a lg cyon su910 mobile phone. but, can't play mp3 player. how can play my lg cyon su910 mp3 player? needed to any software install to the phone for the problem???
The LG Cyon can only support music within the MUSIC folder on the Mini SD card, put all the MP3's in the Music folder.
Also, it only supports wmv's and MP3's if my memory serves correctly.
Regards
Jun 22, 2011 | LG Cyon
How can i free up 10mb ?
The only way you can free up space o the player is to remove some music on it or better remove all the music first and save it to your computer and then put it back again....
Apr 23, 2009 | Philips GOGEAR SA6045 MP3 Player
Help Needed With LG Prada
Have you checked the manual for any assistance? You seem to be following guidelines appropriately and I'm unsure why your still having difficulty. The proper way to sync music files is a simple as copying and pasting.
Mar 13, 2009 | LG Prada KE850 Cellular Phone
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Mp3 player
Please could you describe the funny sounds? Also does this happen with any track that you have recently added? Regards
Sep 27, 2007 | LG MF-FE502 MP3 Player
366 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
patseamur
Level 1 Expert
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
