Question about Konica Minolta magicolor 2430 DL Laser Printer
Konica minolta 7416MFG saying paper jam but i removed sll the papers without tearing
    President:
  • Konica Minolta Expert
  • 347 Answers
The door or cover is not properly closed or it may still have piece of paper inside it.
Posted on Jun 19, 2010
Paper jam - Konica Minolta 5670en tray 1 think paper. I can successfully print 110lb from main tray. When I load in tray 1 , it jams exciting the fuser. Is there something I need to clean or adjust?
I have had a lot of jams because of a little torn paper is in the path of the paper. Need to follow the path. Removing paper just won't fix it. You may need a flash light and a pick sometimes and look in the area of the leading edge of the paper where it stops.
Apr 03, 2016 | Konica Minolta Office Equipment & Supplies
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
My Konica Minolta 1390Mf says open front cover and remove paper, but there is no paper inside please help
Normally when you get a remove paper jam and there is no paper, it is because the paper didn't make it out of the tray. Open the front door and remove your toner/drum unit. If you look inside you will see a gray half circle roller, try cleaning this roller with mild detergent. Do not use alcohol, this will dry out the roller.
Apr 14, 2010 | Konica Minolta PagePro 1390MF All-In-One...
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta cf2002 misfeed error
Have you checked that the paper matches the operator panel and the paper draw, landscape vise portrit
Mar 17, 2009 | Konica Minolta DiALTA CF910 Copier
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Feb 04, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Konica Minolta magicolor 2430 DL Laser Printer Logo
209 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
