Question about Water Heaters
I have a new water heater. However, its capacity
I have a new water heater. However its capacity needs a boost at times (like with a new jacuzzi tub). Can a tankless product be used to boost the amount of hot water when it is occassionally neeeded? Or is there another alternative?
  • 126 Answers
You could fill with hot water first then add cold to your temp request.The thing to do would of been to buy the tub with its own heater
Posted on May 17, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a new water heater. However, its capacity
No you cannot safely increase the output of a tankless water heater. The alternatives would be to install a heater in your Jacuzzi or to add a tank type water heater to hold water for the tub and then run the haot water from the tankles into the tank. This way all the tank is doing is holding water for you to use and not heating it. Kinda defeats one of the purposes of having a tankles though.
Only other option would be to exchange the tankles for a higher ouput one. Also an exspensive option.
heatman101
Posted on Mar 26, 2010
Earth leakage trips when i switch on jacuzzi
There is a ground fault somewhere...you need to isolate it with an ohm meter.
Dec 02, 2013 | Jacuzzi Water Heaters
Jacuzzi z112
What is the problem you afe having with your Jacuzzi Water Heater?
Is this a Jacuzzi Hot Tub?-- Do you have some indicator lights on?-- what color are the lights?--
Is the Circulating pump running water thru the heater element?
Tell me more!-- Let's walk thru the system, and figure it out-- Mack B
Oct 13, 2013 | Water Heaters
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 26, 2013 | Water Heaters
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
heatman101
Mar 26, 2010 | Whirlpool Water Heaters
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
The Jacuzzi isnt recieving power
yes it could, it might even be the motor, take the electric suply and unplug it see if you can turn the shaft on the motor if not it froze up,, sometimes the get wet and seize, the you have to get a new motor
Feb 27, 2009 | Jacuzzi Allusion 7242 RH Whirlpool HTR...
No water hot
does it have a heater in the circulation line, it should be under the cover and would be in line on the 2 inch pipe that feeds the jets, it should also be on a gfci, check to make sure it is plugged in if this is plugged in and not tripped you need to install a new heater
Dec 06, 2008 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Water Heaters Logo
56 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
