Question about GPS
Garmin gps failure
Suddenly unit gone off whilst car parked -went to screen asking if you want to switch to battery power then dead.on car power adaptor only green light working(normally a yellow one too)-
resetting button no help-still nothing-
Any ideas?
Bought a PN-60. Purchase download for costa rica, will not download software. Did a auto detect, no dive found. This is a new cable and the usb port has port has been checked with other devices. Stuck in Costa Rica with a use gps. Cost of shipping this back is not cheap.
Posted on Apr 19, 2011
My garmin c550 battery is dead and it still work while plugged in car power adapter - I need to reset it as its showing "memory full . All the instructions says that i need to switch off power and...
Try unlplugging GPS.
Hold power and bottom right corner.
Then plugging back in whilst holding buttons/screen.
Though you will probably have to get some new batteries for it soon.
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Garmin StreetPilot c550 GPS Receiver
My garmin nuvi 750 went dead when i got it to
Hello :
Resetting your GPS could solve the problem .
Here is how to reset your NUVI :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 750 GPS Receiver
I have a Garmin Nuvi 750. It went dead suddenly.
THERES A GOOD CHANCE THAT THE CABLE IS DAMAGED OR EVEN WORST THE CONNECTOR WITHIN THE UNIT IS DAMAGED OR BROKEN. TRY USING THE OTHER CABLE IE THE CAR TO UNIT CABLE OR THE USB TO UNIT CABLE IF EITHER ONE WORKS THE OTHER IS DEFECTIVE, IF NONE OF THEM WORK THERE GOES TROUBLE.
Mar 05, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Unit will not power up (with new batteries)
call golflogix at 8779770162. BE SURE TO TELL THEM THAT IT HAPPENED WHEN YOU LOADED THE SOFTWARE UPDATE! otherwise, they might not warranty it.
Aug 03, 2009 | Garmin Golf Logix GPS
Garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Apr 20, 2009 | Garmin GPS 12XL GPS Receiver
Failure to acquire satellites in previously known good reception area...
These units are delicate, and not designed to be serviced by most users. Most people having this issue would have to return the unit to Garmin for service.
Dec 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 gps
You have to be outside with a clear view of the sky for it to acquire satellites. No trees, no buildings, no hills, etc...
Dec 18, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
222 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
