Question about Canon ImageRunner 3025 Black and White Copier
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
Where do I place the envelope on the printer in order to print the business envelope?
  • 1,219 Answers
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
Posted on Jun 30, 2010
How do I set up my Epson Stylus C88+ to print envelopes? Now it is printing on the left side and my envelope needs to be on the right side. It is a business #10 envelope.
Turn the envelope in the printer. There is usually a small image on the envelope drawer. At least on Canon printers there is.
If you have MS Word, you can go Tools Envelopes and Labels
Oct 01, 2015 | Broderbund The Print Shop 3.5 Deluxe -...
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
you must put it in the bypass and put the size and the kind of the envelope
Mar 26, 2010 | Canon ImageRunner 3025 Black and White...
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    LEXMARK X1240 WON'T PRINT ENVELOPES
    I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
    Jun 01, 2009 | Office Equipment & Supplies
    Envelope Feeder is not accepting the command
    > Home > Support & Drivers > Knowledge Base
    Solution --> Phaser 4400 Printer: Printing envelopes
    Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
    Guidelines for envelope printing
    • Use only paper envelopes.
    • Do not print on the back of the envelope.
    • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
    • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
    • Envelopes may wrinkle depending on weight and stiffness of the envelope.
    Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
    • Select faceup.
    • Clear Clockwise Rotation.
    • Select the feed method with the image centered and the stamp on the envelope to the upper left.
    caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
    note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
    1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
      • Place the side to be printed faceup.
      • The top of the envelopes should be toward the left of the printer.
    Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
    Printing envelopes
    Print on the Envelopes
    1. Click File , then click Print .
    2. Click Properties , then click the Features tab.
    3. Change the orientation to Landscape and the paper size to envelope #10 .
    4. Click OK .
    5. Click OK again to print.
    Nov 18, 2007 | HP PSC 2410 All-In-One InkJet Printer
    Dell A920 won't print envelopes
    I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
    Dec 02, 2006 | Dell A920 InkJet Printer
    Canon ImageRunner 3025 Black and White Copier Logo
    158 people viewed this question
    old marine
    old marine
